Searching Holley R4056-A1
Hi folks,
I'm looking for a new center-carb for my '69 L68 autom. Should be Holley Part-# R4056-A1.
I've bought several carbs from Jerry Luck at Hazelwood MO in the past - but he died in April this year .
Do you have another adress, to buy a good carb for a reasonable price?
Greets from Germany
Gerrit
Greets from Germany
Gerrit
Thanks for your suggestion - but I need the correct equipment.
My car ist "numbers match" an should stay in that condition. Another carb is out of discussion. I could accept another date-code - but not another carb.
Gerrit
Gerrit
the 4056 is the center carb of a tri power two barrel set up. A 4160 is a type of 4 barrel carb, totally different.
what is wrong with the current 4056 that prevents a rebuild from correcting the problem?
I just want to have a spare carb for a quick replacement. So I have time to repare or rebuild the leaking or disfunctional carb if it is necessary.
My Vette is driven all over the dry seasons - not only a show-car or a trailer-queen.
Does anyone here has a good adress to buy one - or has such an item for sale himself?
Regards
Gerrit
Regards
Gerrit
