Distributor with NO advance?
Hi all,
I am still, after many years, getting to really know my car. I started looking into a Pertronix or similar conversion as opposed to the points system. However, as I look further into my car, I noticed I do not have any mechanical or vacuum advance system at all. I dont have the vaccum can on my distributor, and I dont have any swing weights, just standard points. Is this weird? I feel like I should have something? The car doesnt hesitate to get to 60 MPH.
Sounds like its "pinned."
Looks like an old Mallory dual point. The advance is below the breaker plate.
Looks like a dual point locked distributor, generally used for racing, but can work well on street cars with big cams. You don't get the advantage of vacuum advance at light throttle (hiway cruising) and the high initial timing can cause hard starting.
I've tried them on motors that like high initial timing and limited total advance, like on my supercharged boat motor.
Google it, you'll find pros and cons. Mostly cons on street motors.
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,920 Likes
It's a Mallory, and Mallory uses an advance system like MotorCraft where the advance system is located below the plate that the points are mounted to. You have to pull the points out and remove the mounting plate to see the springs and weights.
Lars
Thanks guys!
There is a lot of info there, I will start looking for a replacement come winter time, with a vacuum advance. Has anyone had good luck with pertronix?
Lars
Alright, another question. Billet distributors seem to run about $150/$200, so is there any reason to buy an old gm one when new ones are quite cheap?
Lars
