1973 Turn Signal lever
Just need some advice. I am replacing my ignition cylinder lock on my '73 C3 with tilt and telescoping. Does the signal lever just pull out with a good tug as in other gm's or is there a screw that holds it in? I tead jim sheas article but do not see the threaded hole that can be acessed on the side of the column. Anyone else run into this issue? Thanks!
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Willcox
