Adjustable strut rod froze
I have a set of used adjustable strut rods that I cannot brake loose. The nut is tightend down. So I have the bushing end in a vise and I am trying to break the nut loose and can't get it to budge. I realize one side reverse thread. Anyone got any suggestions. Thanks
The Punisher (07-02-2017)
Then a brake line style open end wrench assuming you can't get a box end over the bushing to get to the nut.
I adjusted mine on the ground, put grease between 2 vinyl floor tiles and put under each rear tire, lets the suspension relax. I cut down an aluminum level so it sits against the wheel lip and adjust the rod to get the setting you want.
You could also adjust it and roll the car back and forth to settle it then check camber.
The Punisher (07-06-2017)
The Punisher (07-07-2017)
