Where would I buy R 12 refrigerant?
Old 07-08-2017, 06:00 PM
PJLUCAS
1st Gear
PJLUCAS's Avatar
Default Where would I buy R 12 refrigerant?
1976 Corvette, I need refrigerant. It sounds like I should stay with the R 12, where is the best place to buy it?
Old 07-08-2017, 06:07 PM
Big2Bird
Big2Bird's Avatar
Received 1,014 Likes on 808 Posts
I buy mine on FleaBay.
Old 07-08-2017, 06:21 PM
Dynra Rockets
Dynra Rockets's Avatar
Keep in mind the stuff marketed as 12a is not R12.
R12 was outlawed a long time ago for end consumer sales and install (need an EPA license to buy new). The "12a" stuff is not a real ASHREA refrigerant name and is also technically illegal to install in a mobile system. It is actually about 2 oz of propane (R290) sold for something like $25 just for the convenience of the fitted can.
Propane is a great refrigerant and in only 2-4oz is not going to cause a big bang. As a hydrocarbon it will also carry to old oil properly as well (the biggest issue with converting to 134a).
That being said I have used it on a couple of daily driver R12 cars in the last few years. I typically use a 2 oz can of the '12a' propane stuff and augment with 134a (no oil) to the minimum pressure and havent had any issues in the 4-5 years been doing (have to do annually as the molecular weight of R290 and 134a is much less than R12 so WILL leak)
Old 07-08-2017, 06:24 PM
oldboat
oldboat's Avatar
when i lived in california i would buy it at the good guys car show / swap meets. it was about twenty five bucks per can.
Old 07-08-2017, 07:15 PM
Richard454
Richard454's Avatar
Received 3,216 Likes on 1,729 Posts
Try Craigslist-
in Atlanta a guy has all seven cans for $140
Old 07-08-2017, 07:46 PM
BlackC3vette
BlackC3vette's Avatar
Have you considered converting over to 134a? It's not all that crazy complicated. The R12 is difficult to find and very costly. If your keeping the vette ( I like the 76), it's something to think about.
Old 07-08-2017, 08:23 PM
jb78L-82
jb78L-82's Avatar
You can get it on ebay and no you are not required to have an EPA license to buy it. Once you have it, if you have an R-12 system, just put it in.....unless you want to convert to R134A. Same nonsense applies to R-22 for central AC systems now that it is being phased out....You can buy R-22 without an EPA license as well.
SpeedRacerMach (07-10-2017)
Old 07-09-2017, 10:37 AM
gjohnson
gjohnson's Avatar
Envirosafe is where I buy mine. R12 Compatible
Old 07-09-2017, 11:18 AM
Dynra Rockets
Also propane. Again, there is no issue with propane as a refrigerant in my mind as long as you know you are buying propane.
Old 07-10-2017, 10:29 AM
GUSTO14
GUSTO14's Avatar
Received 1,962 Likes on 1,283 Posts
Originally Posted by Richard454
Try Craigslist-
I would urge caution when buying cans of R12 such as the above. The amount of corrosion on these old cans can be deceiving. I purchased 4 or 5 cans a while back on ebay that showed a similar level of corrosion, at what seemed like a reasonable price. It turned out one can, that appeared sealed (no visible puncture) was completely empty. A second can began to immediately leak as I attached the clamp to the top of the can, before I could even attach the hose and puncture the can normally. Corrosion like that visible on the above cans is the enemy.
I'm not saying don't buy R12 this way, but do be aware that in many cases these cans are decades old, and were not stored for long term use. They were consumables that would normally have been used within a few years. Now people that find them are selling them, in many cases without realizing how fragile and possibly useless they may be.
Good luck... GUSTO
Old 07-10-2017, 10:58 AM
71 Green 454
71 Green 454's Avatar
Received 1,186 Likes on 650 Posts
Not to cause any problems, but has anyone tried using R152A in an R12 system? I ask because some guys have in other car forums I belong to because they were unhappy with R134a conversions.
It's sold as an electronics duster.
I wouldn't do it, but it's an interesting idea.
http://www.autoacsystems.com/fasttrack/r152tests.html
https://www.corvetteforum.com/forums...frigerant.html
Old 07-10-2017, 12:32 PM
Richard454
Richard454's Avatar
Good luck... GUSTO
Yep- Craigslist -in person- at a public place,
Old 07-10-2017, 12:47 PM
Big2Bird
Big2Bird's Avatar
GUSTO
Easily avoided for $12.00
http://www.tooltopia.com/robinair-10...FVBbfgodSe8Dsw
GUSTO14 (07-10-2017)
Old 07-10-2017, 01:12 PM
GUSTO14
GUSTO14's Avatar
That looks like a better idea...
I need to pick one up, it may save a can or two over time.
GUSTO
Old 07-10-2017, 03:06 PM
jb78L-82
jb78L-82's Avatar
That is one solution!
I have several old R-12 cans that I need occasionally that are at least 20 years old. They all have surface rust and never been a problem to use......as is.
Old 07-10-2017, 06:20 PM
gjohnson
gjohnson's Avatar
Its not propane from envirosafe that I bought
Old 07-10-2017, 06:22 PM
juanvaldez
juanvaldez's Avatar
Mexico.
To Where would I buy R 12 refrigerant?
Old 07-10-2017, 06:38 PM
Red86Z51
Red86Z51's Avatar
Finalist 2020 C4 of the Year - Unmodified
C4 of Year Finalist (stock) 2019
Same here. I get the Envirosafe Industrial from them off of ebay. Much better than R12 in every system I've put it in. No need to change oils, no flushing the system before install, will NOT damage your system and poses ZERO threat of corrosion if exposed to the atmosphere as R12 will. You do not have to pull vacuum on your system before charging...you charge your system at atmospheric pressure. One 6oz can of the Envirosafe Industrial = 18oz of R12.
Also propane....
Where in the world did you ever get THAT misinformation from??? Sounds exactly like another case of "internet-parroting" to me. Unless you can PROVE that statement in writing, you should not attempt to spread unfounded mis-information that is untrue and a complete load of bunk. Period.
Old 07-10-2017, 06:47 PM
jb78L-82
jb78L-82's Avatar
Where in the world did you ever get THAT misinformation from??? Sounds exactly like another case of "internet-parroting" to me. Unless you can PROVE that statement in writing, you should not attempt to spread unfounded mis-information that is untrue and a complete load of bunk. Period. :crazy2:
I agree...really irritates me when folks spread misinformation about our cars and stuff like R-12...More irritating when they continue to debate but offer no sources or documentation to support their false narratives................
Old 07-10-2017, 07:26 PM
Dynra Rockets
Look at the MSDS for your can. If the can says says "R290" or "R-600a" or "Hydrocarbon" or "flammable" or "Petroleum based" or "petroleum gas" or "petroleum distillate" then it is likely propane or butane.
A quick Google...
http://www.es-refrigerants.com/docs/14249_310.pdf
Says it is "Petroleum gases, liquefied"
It then says the chemical is "68476-85-7" which is Propane ... https://chem.nlm.nih.gov/chemidplus/rn/68476-85-7
Really irritates me when .... nevermind
Quick Reply: Where would I buy R 12 refrigerant?
