Indian Head Permatex on Freeze Plugs
Yes, you can put it in dry. But, if it has a slight leak, then you have to go thru the trouble of removing and then re-installing. Of course the engine is back in the car at the time. What the factory did was based on time and cost factor spread out over the production run. So, I don't look at what the factory did or did not do as the holy grail. Freeze out plugs have long been an issue and I found a sealer made by Hercules (Blue Block) that does a great job. Just wear gloves putting it in, the stuff likes to get all over your hands and doesn't like to come off.
in 50 years I have never heard of a freeze plug leaking, because it was installed dry.
But I do use the Brass version, they are softer and conform/seal better, and do not rust.
If you have all the original GM parts and the same tooling that was used to install them at the factory, you can install them dry and they will seal. Otherwise, wipe a bit of sealer on them...just for "funsies".
Why take any chance that they might leak.
Most lip seal casings and some cup plugs are treated with a sealing-paint type material on their mating surfaces. That is used as a sealant. If it's good enough for new parts, it should be appropriate for you.
I've always used a light coat of sealer on the plugs I install. helps lube a bit as it is pressed in and seals any irregularities in the block surface. I imagine brass seal better but I've always used steel. This is how I was taught in auto shop when I was a mechanic. never had a failure that way.
15 responses on a freeze plug install.
It's like debating paper or plastic.
