Power Brakes on '68 failure........
Nam Labrat
Received 4,173 Likes
I completely rebuilt the brake system on my '68 convertible project, and it has worked perfectly for 3,000 miles/one year. No leaks/full master cylinder/17 "lbs." of vacuum at the manifold.
A few days ago the pedal started getting very hard. Now it has gone completely to the floor.
There are still NO signs of leaking anywhere/master cylinder is still full.
I have read about 15 threads on the subject before I do any troubleshooting.
Has anyone recently had a similar problem/What was the cause and solution?
Thanks in advance.
Thanks in advance.
Check you're rubber hoses first ,than you're master
Nam Labrat
I replaced all rubber hoses with quality U.S.hoses.
I'm out of town...I'll try it Friday.
Sure did.....I have rebuilt EVERYTHING on the car related to brakes/bearings/rotor face run-out/etc.
Thanks everyone for the replies....I'll update thread this Friday....also will keep checking thread replies until them.
Nam Labrat
Today/Sunday
Tested the master cylinder with the engine running = Pedal goes to floor.
-------------------------------------------------- off = Pedal goes to floor.
Pedal will not get firm by constant pumping with engine Running or Off.
I will unbolt master cylinder and check for fluid leaks.
