my C3 brake problem...help!
I have a 1976. she's a beaut and i love her, but just started giving me the hazards whenever the brake is pressed. both front and back oranges turn on.... anyone have this happen, and a possible fix/remedy? thanks all!!!
If you haven't messed with anything and this started, it's more than likely a bad ground/grounds. I can't specifically tell you which ones to check, but someone with the knowledge will chime in and tell you where they are. You'll need to clean them up and tighten them. Good luck.
Duane
Duane
Duane
Duane
thanks, was just out messin with 'er again.... turn signals don't work...thought they were the hazards, but its the turn signals that light up with the brakes, and when i depress the brake, the dash turn signals light up too. both of the front side marker lights are fine and working. maybe this helps diagnose?
Dementer sole survivor
Received 6,291 Likes
2016 C3 of Year Finalist
Do your brake lights work? Sounds like a bad ground to the tail
lights
lights
