Replacing My Holley with a Qjet
Hi All, Just bought a correct Qjet (7029207) for my '69 L46 to replace my
600 holley. I have to now figure out what I'm going to do for a choke as
I have an Performer RPM manifold so the std divorced choke actuator
won't work. I want to replace it with an electric conversion, but all the
units that I have seen all bolt up to the original choke stove, on the
intake manifold.
Anyone got a suggestion/solution/work around for this problem?
Any help provided would be most appreciated.
Mark
intake manifold.
Mark
Received 2,112 Likes
For what its worth, I run a Holley 650 DP with elect choke on a Edel Perf 2101 (for now). With the air cleaner off, I can turn the key and watch the choke partially close. After warm up, its fully open and stays fully open. No choke stove was ever hooked up in nine yrs.
I rebuilt one for a friend years ago with a manual choke.It worked well but you have to find the best cold start position with the cable. I am not sure where he bought the kit but I think it was a universal one.
The electric is also an option maybe you should contact Lars. I am sure he can steer you in the right direction.
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,920 Likes
There is no electric choke conversion for the divorced choke carbs that does not bolt to the intake manifold exhaust crossover.
Lars
Lars
76strokervette (08-14-2017)
you also cannt bolt the Quad onto a Performer RPM without an adaptor, the RPM has only the bolt pattern for a square bore carburetor
Actually, Edelbrock is now offering a Performer RPM Q-Jet under part number 7104. But it has no provision for mounting a divorced electric choke.
Here is the Edelbrock note with this manifold:
"Will not clear stock Corvette hood. No provision for exhaust-heated chokes."
If you want to use the Q-Jet with minimal hassle, you might want to reconsider using the RPM manifold and go with the standard Performer with a Q-Jet bolt pattern and choke provision.
Lars
M A Fry (08-15-2017)
