Is cam in right?
Is the vacuum steady, but low, or is it low and erratic? The needle should not vary very much. If it is "bouncing", along with everything else you are describing, you wither have wiped a cam lobe or two, or the lifters are broken...might also explain why the one keeps loosening on you...
I had a motor with a mechanical cam...two exploded lifters, but I could still get it to run with a very rich mixture, but would backfire through the carb from time to time, and the idle was always rough...
didn't realize the lifter issue until I finally got frustrated and tore the motor down...
The OP needs to fix the rocker issue, and then confirm TDC. After that, he can move on to the timing and carburetor tuning to get his engine running right.
mrvette (08-20-2017)
I'm sure that most fellows and gals on here know how to find top dead center, but maybe there are a few that don't, so I will post a tutorial that I wrote many years ago to fill the gap for those few......
http://www.crankshaftcoalition.com/w...op_dead_center
Received 2,127 Likes
Theres always the possibility the cam was installed wrong. Not 180 out but another way. Most timing chain sets come with the option of changing the timing of the cam. There are three markings and three slots or keyways on the crank sprocket. Of the three, I believe one is straight up, one is 4* advanced and lastly 4* retarded. Which mark did someone use and not double check?
