Oil on plugs after rebuild.
Old 01-14-2018, 08:48 AM
  #341
LenWoodruff
LenWoodruff's Avatar
Originally Posted by HeadsU.P.
After listening again, you are running a V7. One cyl is lazy.
Loose rocker arm I believe. But why? By chance, was Zinc added to the oil before this last rebuild?
It is running Rotella T4 10w-30 which has over 1100 ppm zinc in it.
Old 01-14-2018, 08:50 AM
  #342
LenWoodruff
Your best bet is to actually see the valvetrain running at idle. Purchase 8 rocker arm clips that contain oil spray from the rocker. Remove one valve cover only, stick a narrow piece of bent cardboard between the valvesprings and the gasket pad. With the clips in place, start it up and look-listen to whats going on. Look for a valve that doesn't open as far as the others. Maybe a rocker stud pulled out, broken spring, bad lifter, bent pushrod, who knows?
And please stay away from that misnamed auto shop. Exhaust bolts loose? Unacceptable.
Thanks.
Old 01-16-2018, 07:38 PM
  #343
LenWoodruff
So the noise was resolved today. It was the #2 Exhaust Rocker. It was tightened down about 3/4 of a turn.
Not sure why this one needed that as the lock nut is further down on the stud compared to the other rocker arms.
Since I have screw in studs I wouldn't think it would be pulling out.
But the noise is gone now.
I only drove it back home today so I hope to get more miles on it later this week.
Old 01-16-2018, 07:45 PM
  #344
calwldlife
calwldlife's Avatar
St. Jude Donor '22
interesting.
lifter.
i hope it is finally resolved and you get miles and miles of
trouble free operation.
good luck
Old 01-16-2018, 08:22 PM
  #345
LenWoodruff
Originally Posted by calwldlife
interesting.
lifter.
good luck
Me too! Thanks.
Old 01-16-2018, 08:36 PM
  #346
zwede
zwede's Avatar
Don't want to be pessimistic but that sure sounds like a cam lobe going flat.
  #347
Peterbuilt
Peterbuilt's Avatar
Received 1,243 Likes on 965 Posts
LenWoodruff (01-16-2018)
Old 01-16-2018, 09:07 PM
  #348
LenWoodruff
That bothered me too. Why would just 1 rocker need to be adjusted more than the rest of them?
I was worried that this went back to the coolant in the oil that I drove it for a few miles.
They checked the bearings and they were ok. But there was no way to check the cam.
Is there anything to check to determine if the lobe is going flat?
Old 01-16-2018, 09:17 PM
  #349
calwldlife
calwldlife's Avatar
St. Jude Donor '22
the lash is set on the back side of the cam.
never seen a backside wipe.
if the lobe wore off, then the lift would be small.
to check, dial indicator to see if it still has the
spec lift.
Old 01-16-2018, 09:22 PM
  #350
'75
'75's Avatar
If it's the cam going bad, you won't have long to wait for it to start making noise again.
Old 01-17-2018, 07:22 AM
  #351
fishslayer143
fishslayer143's Avatar
first it did not click..then it did, and the clicking stopped when you tightened it down much farther than the others? more likely a collapsed lifter and you just took up the slack.. now its a SOLID lifter .. next to go is the pushrod
Old 01-17-2018, 07:28 AM
  #352
LenWoodruff
Ugh. These were brand new Crane Lifters to go with the Crane Blueprinter cam that was installed when they built the engine.
Old 01-17-2018, 08:07 AM
  #353
Lagonia
Lagonia's Avatar
Old 01-17-2018, 03:34 PM
  #354
REELAV8R
REELAV8R's Avatar
Received 1,033 Likes on 852 Posts
I had a similar issue with rockers getting loose on some roller tipped magnum rockers. Turned out to be the pivot ***** were wearing excessively due to higher spring pressures.
Take a look at the pivot ball, you’ll see the wear compared to a new one if this is what’s going on.
LenWoodruff (01-18-2018)
Old 01-17-2018, 06:30 PM
  #355
DUB
DUB's Avatar
Received 2,713 Likes on 2,321 Posts
For what it is worth:
I got called to shop due to an engine was clicking and it had several hundred miles on the fresh rebuild.
It was the rocker arms making noise...so I took off the valve covers an using one of my small LED lights I put it down by where the push rod goes into the lifter so i could see it...and with that push rod being loose....the plunger in the lifter was stuck and not coming back up like it should....while the lifters near it worked as designed.
DUB
Old 01-17-2018, 06:46 PM
  #356
HeadsU.P.
HeadsU.P.'s Avatar
Received 2,108 Likes on 1,619 Posts
Just to satisfy the curious, I think I would remove the valvecover, loosen the rocker arm on the trouble maker, pull the pushrod and inspect both ends. Try to wiggle the valvespring and like Dub says, shine a light on the lifter.
Then remove the rocker completely, inspect pushrod cup end, check the rocker ball.
Double check that the rocker stud is indeed flush with the head, still. And that the stud threads look all right.
Old 01-17-2018, 07:13 PM
  #357
Kingtal0n
Kingtal0n's Avatar
sorry this shouldnt be here mistake
To Oil on plugs after rebuild.
Old 01-17-2018, 09:26 PM
  #358
derekderek
derekderek's Avatar
Received 3,387 Likes on 2,632 Posts
Now, where were we? Lifters and lobes. When a lifter wipes out, it doesn't change the preload, just the amount of lift. Only the lobe gets smaller, not the base circle.
Old 01-18-2018, 08:46 AM
  #359
LenWoodruff
DUB
Was there a resolution for this Dub?
Old 01-18-2018, 08:48 AM
  #360
LenWoodruff
I think I will try that this weekend when it gets warmer here in Dallas.
Quick Reply: Oil on plugs after rebuild.
