Oil on plugs after rebuild.
#101
I don't believe I have ever seen a valve spring rotate on a running engine. I would think if it did, there would be less than 50 lbs of closed pressure. But thats another story.
Even brand new aluminum heads may not have valvespring shims. That spring shouldn't be going anywhere but up & down. There is no rhyme or reason for a spring to rotate.
Shims are used to insure that each and every valvespring height is the same. This measurement is done with a valvespring height micrometer ($50). The highest height springs are then shimmed accordingly to match the shorter units.
Watch this video.
Mike
#102
Received 2,127 Likes
Ok. Remind me not to turn 8500.
#104
You had to do that.....didn't you. Hardened spring shims are always used.
#105
Interesting that the next valve over doesn't have a spring on it. H-m-m-m-m-m. Is this a fake video?
#106
Spintron is a machine used in engine development. It has a powerful electric motor that can spin components to whatever RPM is desired. They have high speed cameras and strobe lights to capture the action.
Mike
#107
Sooooo, in reality, with real valves, real valve springs on a real engine at a realistic RPM the valvespring still rotates? Could be I guess.
#109
Update on the oil on plugs issues.
I changed to Rotella 10W-30 T5 synthetic blend and have driven it about 250 miles.
It has used more than 1/2 quart of oil. While that is down from the Castrol it is still too much.
Based on the posts here are the 3 most likely possibilities causing this issue in or from best to worst scenario.
1. Intake Gaskets leaking. I checked many of the plugs and the oil side of the plug is the side up facing the intake port. I know this because I marked the plug with a marker and when it was installed the mark was pointing up.
2. Oil Valve seals. Based on the bore scope pictures I took the valve heads are accumulating oil deposits. This typically means the oil seal. But I do not get any oil smoke on startup.
3. Rings. This is the worst possible situation I think. But I don't know how to determine that this is the issue.
I just want to confirm that I have the possibilities correct before I talk to the engine build again.
#110
A leak down test will tell you if the rings are the problem. Unfortunately, that doesn't really tell you much about the oil rings. It's more about the compression rings.
ctmccloskey (03-05-2022)
#111
The following 2 users liked this post by v2racing:
73racevette (09-19-2017),
vette8121 (10-09-2017)
#113
Pretty good bet. The top 2 compression rings do scrape the cylinder walls, but if the ring end gaps are funky the oil will still get by.
Earlier post was about the oil ring spacer having the ends stacked- if that happens the spacer will cut a ditch in the cylinder wall like it was broached. Big time ugly.
And I agree with v2racing-- you've been fighting with this enough it's time for your builder to step up.
LenWoodruff (09-12-2017)
#114
Another way we use to tell if vavle seals were bad was to see if they slid easily on stem. They should be able to slide but still have a pretty good grip, and they should be able to kind of bend on the stem...if they feel rock hard and cant twist and angle on the stem then they are likely hard. HOWEVER....if those vavle seals are older, there are oil additives to soften them. But truth be told what happens i believe is small cracks form on the inner rubbers and oil slides through.
To make a long story short and to help put you at rest....oil on top of plugs is usually a sign of bad valve seals. Yes its POSSIBLE that intake is leaking but i would think leaking oil through the intake would make engine run like crap....the vacumn leak alone would be enough to make it not even want to idle.
#116
It looks like valve seals to me. Notice the gold on the vavle stems....that looks like oil to me. If you suspect the rings, take out the plugs and rotate engine to bottom of stroke, the walls should look like chrome by now, and if there is any type of problem you will see the cross hatch pattern worn uneven, and if oil rings were installed incorrectly, which i dont think is the case, you will see major scars and scoring on walls, and your car would be smoking enough to scare you. In order to overlap an oil carrier or spacer and still be able to cram those oils rings in there will definately do major damage to walls. I would think the assembler would have a hard time getting pistons to slide in..
I will be talking to the engine builder tomorrow.
#117
I agree with SAN. First things first, take the easy-cheap way out, then move on.
New valvestem seals & valvecover gaskets. You can get a tool to compress the valvesprings right on the heads for $50. You can use compressed air to hold the valve up with another cheap tool $12. But I have better luck with three feet of rope shoved in the sparkplug hole, then bring the piston up to TDC. Wack the valvestem with a mallet, compress spring, remove splitlocks with magnet, release spring, inspect / replace seal. If this doesn't cure the problem, then pull the heads. (with new seals) Its not too bad a job to change seals if you get the front end up on ramps. Save your back!
#118
if it was your build that got new valve guides then wouldnt they have used new seals as well?
in any case, ive had engines use oil from a new build...and lots of it...i didnt actually measure it but how i fixed it was changing the oil continuously, took about 5-6 oil changes, was doing them weekly, then magically oil consumption dropped from a quart every 3-4 days to NOTHING....the most interesting part was with every oil change, as soon as the oil looked a little dirty is when the consumption would get worste. After like i said 5 or 6 changes it stayed super clean and engine didnt use a drop until it got a little dirty again, and by then it was due to be changed, like over 3000 miles, and would go down about half a quart. I however didnt do work on the heads, just a clean and prep.
#119
im not sure if you said they installed new vavle guides? Or if was someone else talking about their own build...
Tomorrow I will talk to the engine builder to get this resolved.
#120
