trouble removing bolt from trailing arm
I read somewhere on this forum about others having a problem removing the bolt that holds the trailing arm to the frame. But after a quick search I couldn't find it. Anyways, I'm doing a frame-off resto on my 72 and the right trailing arm bolt is frozen in place. I tried soaking it in PB Blaster and also heated it with a torch but it won't budge. Anyone have any suggestions? Thanks!!
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,924 Likes
Sawzall with a good blade will cut the bolts in about 30 seconds per bolt - trailing arms come right out with no problem, and with no damage to the arms or to the frame.
Lars
Lars
LenWoodruff (08-27-2017)
I removed the shims and tagged them for location and sawed right through the bolts. Don't saw through that thick stake of shims. Get them out of your way. I used a Sawzall too. 30 minute job at most.
Just as an update, I did get the nut off without a problem. It's just the bolt won't move. Even if I put a breaker bar on the head I can't budge it. My question is, if I cut the bolt in half will I still have problems removing the head half?
Had a 1976 L-82, 4-sp
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes
Royal Canadian Navy
I couldn't remove any of my shims as they were seized in there darn good after 40 years. Sawzall cut right through them. Once the bolt was cut through, the shims were able to move enough to pry them out. Once the shims were removed, the trailing arm pretty much fell out and the remaining head half was easily removed.
I must be living right. On my '75 I just did a complete rear suspension rebuilt, car has over 100K miles. At all came apart with hand tools. My trailing arm bolts looked new when I pulled them out.
Well, I just went out and bought a new sawzall. My old one was a Craftsman model from the 60's!! It was my dad's. Couldn't find a metal cutting blade so I just got a new one. I'll let everyone know how it works out.
The bolt is out!! Had to torch it out because a sawzall wasn't working. Everything else was already removed from the frame so nothing was damaged. Now off to the sandblaster......
