Wiring/Ground question
Old Aug 25, 2017 | 01:07 PM
tehjrow's Avatar
tehjrow
Default Wiring/Ground question
While troubleshooting my blower motor I found that it wasn't grounded. I followed its ground wire from the blower, into a bundle, out of the bundle and then into a five wire crimp. Using a multi meter I found there is no continuity between these wires and ground. When I grounded them with an alligator clip wire to the alternator the blower motor started working.
Of the five wires I know the following:
1 goes to the blower
1 is about 5 inches long and cut off
1 is about 5 inches long and goes to a spade fitting and isn't connected to anything
3 are a complete mystery
So, I'm guessing a previous owner did something weird here so I need to know where these wires normally ground. I'm looking in the AIM for my 1981 C3 but can't follow where the ground is supposed to go. Here are some photos.
Old Aug 25, 2017 | 06:32 PM
Peterbuilt's Avatar
Peterbuilt
The ground for the blower motor starts at the wiper motor then connects to the blower motor and ends at a bell housing bolt down by the starter.
I'm not sure if you are describing the 'starter extension harness' wires that are loose.
http://www.zip-corvette.com/81-82-st...g-harness.html
81 schematic:
https://docs.google.com/viewer?a=v&p...TkzNDc2YzgzNGU
Old Aug 25, 2017 | 09:38 PM
TimAT's Avatar
TimAT
That "5 wire crimp" is the starter extension harness. If you look at the wiring diagram provided in the previous post, it's the connector just to the right of the alternator on the first page. I'd bet that the spade lug in your picture goes to the wiper motor as a ground and then the one to the bellhousing bolt is cut.
Old Aug 25, 2017 | 10:45 PM
Richard454's Avatar
Richard454
AND that came from the factory like that!!
Old Aug 26, 2017 | 12:00 PM
tehjrow's Avatar
tehjrow
Yup, that's it exactly. Found another cut wire going to bellhousing. Connected them and the blower and my wiper work now (after connecting that spade to the empty spot on my wiper motor).
To Wiring/Ground question
