1973 Passenger Side Hood Wont Release
Just got the new motor in my 73. My engine builder put the hood on and now cant get it open. when he hits the hood release both sides pop up, but the passenger side seems like its only come up off the initial release, but not coming up all the way. i can hear and feel the latch working, but its not letting it up all the way. Any thoughts or suggestions would be greatly appreciated. scott
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The latch is probably just a tad off in adjustment. Try pushing the hood from side to side and see if this lets it release.
Willcox
we have been trying that, we will try it some more. i can see from lifting up the drivers side that it is releasing on the pass side, it just wont come all the way up. thanks willcox, much appreciated.
Received 2,878 Likes
Hi Scott,
Since from what you describe it sounds like the female latch is releasing the probe but it's then getting caught on part of the latch.
Have you tried pushing down on that corner of the hood with some force with the latch set, pulling and holding the interior handle, and then quickly releasing that corner of the hood in hopes that the spring will help the latch to fly free of the probe?
Regards,
Alan
To help you visualize what both parts of the latch look like.
Regards,
Alan
Hi Scott,
Regards,
Alan
Regards,
Alan
I believe we have alan. but i will try it again. i know the cable is operating from side to side and its definitely opening the mechanism all the way out. thanks alan
We got it, you guys were correct. jacked it up with stands under the door fender seam. let it sit for about 3 hours. tried it and it popped right up. Thanks again gentlemen.
i am having the same problem ,same side, except that it started with a broken primary release cable and have been trying to open it with just the drivers side up on a stand. your post has given me the re assurance that i can get it by messing with floorjacks on both sides or just the pass side i posted this problem a few days ago and as i responded to a helpful question i saw your post and figured i would chime in Thanks
Former Vendor
Now make you a hood alignment fixture and you'll be set.
i hope it works for you. we left it up on stands for hours, and when we came back it settled just enought to open. mine didnt have a broken cable, just a bad adjustment,lol Good luck. scott
thanks for posting alignment tool pic and specs, i am about to make one so when i get out to the vette i will be able to get it aligned much faster then trial and try again method that got it stuck in the first place(yes the release cable broke trying to open it, but we had just put the hood back on and guessed at which direction to adjust the hood to open properly Thanks
i wish i could take the credit for it,lol. i just started the thread and everyone jumped right in to help out. its def a very frustrating ordeal. i just had my new motor installed and wanted to hear it run and that happened.lol good luck.
