Opinions on Vortec Marine Hybrid Heads with roller cam
#41
Reconditioned 165cc Dart Iron Eagles made 430hp in this cylinder head shootout, so they also have some power potential.
http://www.superchevy.com/how-to/engines-drivetrain/0606ch-cylinder-head-performance-test/
#43
Maybe the pictures are inaccurate or there are different versions of the heads that use different intake manifolds.
#44
All you have to do to check is look at the e-bay link and the pics, which you think are a mistake and then look at the listed specs, which you might not believe either. I have no dog in this fight, just pointing out the obvious.
#45
I didn't say I think the eBay pictures are a mistake, just that that is one possibility of where the inaccuracy might be. Maybe Hot Rod magazine listed the wrong intake in their article. I don't know, as I don't have any experience with those heads. But, in researching them given the info from Mako, I noticed Hot Rod magazine listed a Vortec intake and wanted to make sure the OP knew to make sure a divorced choke intake will work with those heads or whatever heads he buys. That's all.
#46
http://speedtalk.com/forum/viewtopic...=1&t=33855#top
Contact: Contact WeingartnerRacing
Re: Enginequest Hybrid Vortec Heads
Quote
Postby WeingartnerRacing » Tue Dec 25, 2012 6:21 pm
I have flowed and sold many sets they ranged in flow from worst 237cfm to 252cfm best. Stock vortec 233cfm. Very good heads
Eric Weingartner
Weingartner Racing LLC
918-520-3480
www.wengines.com
Dart Iron Eagle 165 flows 210 @ .500 lift and 138 exhaust according to summit.
http://static.summitracing.com/globa...0ss%20head.pdf
Good rule of thumb is double the intake CFM and that is the Maximum HP capability of the head on an optimized build. Both head probably peak flow about .500 lift
Quote
Eric Weingartner
918-520-3480
www.wengines.com
