What oil for my TH2004R anf T5WC
I need to buy oil for my TH2004R, what oil must I buy?
Is it DEXRON II or III?
I can get Castrol, Valvoline, Mobil and Sunoco.
Also I would like to replace the oil in my T5WC transmission, what oil type is needed?
Thx.
John
Thx.
John
Thx.
John
Thx.
John
Mercon I think it's called.
Redline and Valvoline have ATF that are supposed to be backward compatible to Dexron II (GM ceased licensing the Dexron II name).
Some interesting info on ATF fluids here:
https://www.cartechbooks.com/techtips/autotransfluid
Redline and Valvoline info:
https://www.redlineoil.com/product.aspx?pid=51&pcid=9
https://sharena21.springcm.com/Publi...0-ac162d889bd3
I have no experience on the T5.
My 1984 Hurst Olds has the TH2004R transmission. The Factory Service Manual calls out "Dexron II or equivalent".
And as I see it, then it is the same oil for my TH2004R and my T5WC ?
"D4 ATF
Our most versatile ATF, use where Dexron III®, Dexron II®, Mercon® and Mercon V® fluids are recommended, for use in automatic, manual transmissions and power steering
Popular applications: Toyota Type T-III and T-IV, Honda ATF-Z1, NissanMatic D, J & K, Diamond SP-II, SP-III, Mazda ATF M-V, most BMW, Audi, VW automatic transmissions
Also used with manual transmissions and transaxles like T-5, T-45, T-56 and late-model BMW, provides a GL-4 level of gear protectio"
Is this ok for both my TH2004R and T5WC?
MOBILE ATF 320 - 20 Liter
Mobile ATF 320 is a high performance mineral automatic gear oil, which includes the GM Dexron III G specification.
Mobile ATF 320 is recommended for most passenger and vans with
automatic transmission. Also suitable for power steering systems, hydraulics and certain
manual transmissions where automatic gear oil is specified.
Application
Mobile ATF 320 is recommended for most passenger and vans automotive gear.
Also suitable for power steering systems, hydraulics and certain manual
Mineral AFT oil
ZF TE-ML 14A, 04D, 17C, 03D
MAN 339 Type Z-1/339 Type V-1
GM Dexron III G
Ford Mercon
Allison C-4
Volvo 97341
Application
Mineral AFT oil
GM Dexron III G
Ford Mercon
Allison C-4
Volvo 97341
