Wondering how much space is under the dash for speakers?
So I'm piecing together a sound system for my 1975. I've got 2 woofers for the kick panels, 2 small subs for the rear, and I'll be installing tweeters into the dash pointed at the windshield (To reflect sound. I find this method of installation adds a lot of sound-stage to small vehicles)
The problem I have is that I have no idea how much space is between the upper dash panel thingy and the housing for the gauges.
I want to install a hi-fi ribbon tweeter, but they tend to be fairly deep in size and I'm not sure how big of one I'd be able to get away with (The one I ideally want is a little more than 3 inches deep, 5 inches long, and 2.2 inches wide)
Parts Sherpa
Tweeter (high-frequency) speakers take very little power to create a lot of high frequency sound. And, that sound is direct (line of sight), so reflecting off the [rigid] windshield and then to the listener is a very sound idea (sorry, no pun intended). But, having tweeters that can actually process LOTS of watts is essentially....crazy . So, fairly small and good quality tweeters is the way to go.
Because of how these dash speakers are mounted, installing 'alternative' tweeter designs should be limited to those that can fit within the envelope allowed by the stock mounting system. Going larger than that is totally unnecessary. Also, if you went with hi/mid speakers in the dash, you would end up with a system which had a LOT of vibration and distortion in it. Keep the mids and bass sounds coming from the kickpanels and/or rear compartment area AFTER prepping those areas appropriately for mid/low speakers.
I've done exactly that in my '71 coupe and used 'decent' quality, low power speakers to connect with the stock radio head. That system is 10 times better than the dash-only setup from '70-77, and I highly recommend it.
P.S. If you are using the Delco head, make sure that the 'total' speaker impedance [on each side] equals no less than 8 ohms. If you go less than that, you run the risk of overdriving (excessive current) the output amp stages if you turn the volume up pretty high and send a lot of low frequency stuff through the amp.
