80 Rear Diff question
Old 09-17-2017, 09:10 AM
bschuus
bschuus's Avatar
Default 80 Rear Diff question
I was stuck on a wet grassy hill. My Right rear tire dug a hole and the left rear tire was on dry dirt not moving. I know when car is in the air you can't spin tires in opposite directions of each other. So I was wondering what happened to my posi in this situation?
Old 09-17-2017, 03:15 PM
BlackC3vette
BlackC3vette's Avatar
Having an 80, I would check the level and condition of the fluid.
Old 09-17-2017, 03:47 PM
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,813 Likes on 1,458 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
If you know the car has posi... then you might check the clutches...
Willcox
Old 09-17-2017, 04:21 PM
bschuus
bschuus's Avatar
Willcox
Thanks. I'm sure it's a clutch issue. I was thinking on replacing the rear for a highway ratio anyway
Old 09-17-2017, 08:50 PM
BlackC3vette
The 4 speed has the 3.07 ratio and I believe the automatic had a 3.70. Can you read the stamping on the rear in your vette? Mine I think was on the bottom in front of the cover. Of course that won't tell you if it been apart and different gears installed.
To 80 Rear Diff question
Quick Reply: 80 Rear Diff question
