Headlight Relays - Again!
Old Sep 18, 2017 | 08:39 PM
brian76's Avatar
brian76
Default Headlight Relays - Again!
I have Bosch relays for my headlights. Problem is , I don't have any idea which wire goes into which port in the relay. Any ideas? Thanks
Old Sep 18, 2017 | 08:45 PM
'75's Avatar
'75
On those cube relays, 30 is power in, 87 is power out to headlight, 85 is ground and 86 is power from the headlight switch or dimmer switch.
Old Sep 18, 2017 | 11:10 PM
Richard454's Avatar
Richard454
This might help-
Old Sep 19, 2017 | 07:58 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
This is exactly right.......30 turns the relay on.....86 is the main hot in and 87 the main hot out.
Jebby
Old Sep 19, 2017 | 09:56 AM
lionelhutz's Avatar
lionelhutz
Jebby
At least you got the 87 terminal right...
Old Sep 19, 2017 | 10:37 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
That is what I get for posting before coffee.......early in the morn....
I had 30 and 86 swapped in my head......
Jebby
Old Sep 26, 2017 | 10:30 PM
brian76's Avatar
brian76
Default relays
On the Bosch relays, how many amp fuse does this use? I know that they're 30 watts apiece, but are unsure of what size inline fuse to get
Old Sep 26, 2017 | 10:47 PM
brian76's Avatar
brian76
Default relays
What about ports 87a and 30 ? Are they connected together or do I use 2 separate wires?
Old Sep 27, 2017 | 10:17 AM
lionelhutz's Avatar
lionelhutz
Fuse is based on headlight load. If you run 2 headlights then 30A is likely required. FYI, DOT regulations require protection that automatically resets on headlights in case you care about that kind of thing.
87a won't be used.
Old Sep 27, 2017 | 10:18 AM
7T1vette's Avatar
7T1vette
87a is not connected. The 'line' between 30 and 87a is the internal switch in the relay. As the relay turns on/off, the switch floats between 87a (off) and 87 (on).
P.S. Nice schematic, Richard....
Old Sep 27, 2017 | 06:27 PM
theandies's Avatar
theandies
87a won't be used.
In my circuit I'm using 20amp fuses but I just recently change out the fuses with 20amp self resetting circuit breakers that fit in the blade type fuse holders.
I'm using three relays. One for regular low beams, one for high beams and one for the high beam filament in the low beam bulbs. Probably overkill but it makes my regular low beams independent of the high beam circuit. I think it's a bit safer.
My alternator puts out 14.61 volts and with my upgraded wires to the bulbs I'm getting full voltage at the bulbs. Both low and high beams are halogen bulbs. With my setup the low beams (35 watts both low and high beam filaments) on they draws 4.87 amps - 35/14.2=2.39x2=4.87. My high beams (50 watts) draw 3.42 amps - 50/14.61=3.42x2=6.84 and since each circuit is independent that is the full draw all the time. I could use 10amp circuit breakers but I chose to keep them 20amps so I have a little more fudge factor. Also installed ceramic plugs at the bulbs and with my setup I have several upgrade possibilities.
My circuit:
Old Sep 27, 2017 | 08:33 PM
Richard454's Avatar
Richard454
Nothing wrong with overkill!!!
I actually am running a relay per light- like the Germans do separate circuits for each side.
However- I did upgrade to some Hella's with 80/100watt low/hi and 100watt high bulbs-
Relays fit neatly next to the electric headlight motors where the old vacuum actuator was-and if you look closely the black pieces between the 15A fuses are Ford diodes to isolate Hi and Low beams to run the headlight motors.
And ran some 4GU to power everything up front (headlights/electric headlight motors/horns/dual fans)
Old Sep 27, 2017 | 08:46 PM
theandies's Avatar
theandies
Richard - I remember your setup from some other headlight relay threads.
Old Sep 27, 2017 | 11:07 PM
Kid Vette's Avatar
Kid Vette
Daniel Stern Lighting
Old Sep 28, 2017 | 02:19 AM
brian76's Avatar
brian76
Originally Posted by Kid Vette
This is exactly how I wired mine. Made a hell of a difference ! Thanks fellas
To Headlight Relays - Again!
