Hinge Pillar Weatherstrip Question..69
Hi All,
I've been installing weatherstripping and have one more set to install. That being the one piece windshield "A" pillar strips. My question is what type of adhesive would be best for the lower part of it. The part that fastens with two screws to the hinge pillar. It seems that the upper windshield molding portion would be fine with regular weatherstrip adhesive but should I use something different/stronger for the lower section. Just that my gut feeling tells me regular adhesive isn't good enough in this area for the long term.
Any opinions/suggestions? Thanks Rick
Received 1,468 Likes
Cruise-In II Veteran
Regular 3M worked fine for me.
Yep, 3M-3008 to be more specific. It's the black weatherstripping cement that has the same holding strength as the yellow 3m-3001. Smear a thin coat onto both surfaces and let it air dry for several minutes to get really tacky THEN stick your weatherstripping on.
If you are wanting to use an adhesive on the cupped part of the pillar post w/strip that is held in by the two screws. I personally/professionally do not use any adhesive because the metal inside that portion of the w/strip is good enough due to its rigidity. What I do apply is a thin application of the 3M strip caulk to create a seal....or thin layer of the CR Laurence 7708.
But as it can be done as a person feels works best for them.
DUB
DUB
69L46vert (09-22-2017)
DUB
DUB
