Question On Oii Pan Bolts - Torque Sequence - 454BB
Hi All -
I'm replacing my 74 BB oil pan and have the correct bolt torque info - but is there a sequence that these bolts need to be torqued (first-last)?
Thank You!
Thank You!
No sequence for the oil pan. I usually work my way from the middle out, and watch the edges for any gasket issues while I tighten. Not a bad idea to crawl back under after driving it for a while and re-snug, but not critical.
Received 2,125 Likes
Joe is right. With almost all oil pans, work from middle out and zig-zig side to side. Using the smallest ratchet you own, 3/8 drive, long extension and one hand only will keep you from over torqueing. I just snug them, come back the next morning for the final torque. That way you won't squeeze out all your Permatex.
I agree with all of the above...BUT...the correct choice of sealer will aid a person in getting it done much faster....if that is a concern...like it is for me.
Some RTV sealers are rather creamy and can cause for problems on the gaskets squeezing out or the sealer itself getting all squeezed out when torquing the bolts.
I use the Prematex 'right stuff' which is rather thick and will actually hold up the cork gaskets while a person is trying to get the pan up and the bolts started.
So..I can get all the bolts in and snugged up and come back in few hours and get them tightened and send the car out.
But as always...how a person chooses to do it is up to them....more than one way to 'skin a cat'.
DUB
DUB
DUB
DUB
The sequence of torqueing pan bolts is not nearly as important and torqueing those bolts in "stages". Put bolts in corners finger tight, then install others and torque them to 1/3 of final torque. Make another pass at 2/3 of final torque value. Finally, tighten them all to full torque.
DO NOT OVERTORQUE THESE BOLTS. If you do, you will distort the rail on the oil pan and it will have a hard time sealing.
In some scenarios I use it...but on most of the Corvettes that I work on...some mechanic has already been in there and had screwed things up pretty well..so from straightening out dimpled pan flanges and whatever you can think an idiot can do..I have had to deal with.
I have lost count on the number of Tuned Port engine tubed runner and plenums I have had to deal with where some idiot took a Scotch-brite pad on a Roloc grinder to clean off the factory gaskets and completed ruined the perfectly machined surface. SO when I write 'idiot'... I meant it.
So basically ...when a person gets into a n engine and is trying to get a good seal so something does not leak.,..they may find more than they bargained for.
DUB
I can't agree with you more Dub, it's just irritating.
DUB (09-22-2017)
However, if you use the newer generation Fel-Pro gasket, it has steel sleeves in all of the bolt holes, making it impossible to over tighten the bolts......
74VetteAZ,
I think you have actually started a thread that you have 100% agreement with all the posters here. Well done I would reiterate all the above comments. You're golden !
Using the new Fel-Pro gaskets with the plastic spacers makes it impossible to OVER-SQUEEZE THE GASKET; you can still overtorque the bolts...to the point that they will snap off!
But, that won't over-squeeze the gasket.
Anybody that manages to over-torque oil pans bolts, should NOT be working on cars!!
I also just love it when I go to remove a lug nut and it is on there so tight...I am wondering how it did not snap off due to exceeding the stretch of the stud....and don't get me started on spark plugs.
DUB
100%...but even though that makes total sense that some people should not touch hand tools if they are working on a vehicle......they must be the same people that seem to not grasp the concept of using a manual to aid in in specific torque information.
DUB
DUB
