Help, gasket or something blew after hard acceleration
I suggest you change you oil right now and cut open your old filter to see if there is any metal in it. I'm still worried about where the metal from the old cams wiped lobes went. If it happened over a long period of time you might be OK but if the lobes wiped suddenly then there may be a problem going forward.
Glad you figured out your rough running problem.
If the cam and (we have to assume) the lifters were changed to a higher lift cam, the valve springs probably are not up to the task. Not enough seat or open pressure, coil bind, spring stack, you name it Could even have broken a spring or two.
A lot of people said this cam might be too much for a low compression engine, but I think it was a huge improvement from the stock cam. The cam easily breaks the tires loose in 1st while moving, no clutch kicking just more throttle. It's a totally different car than what it used to be.
Could somebody give me an estimate as to what HP and TQ numbers this engine might be pushing, (flywheel)? I'm estimating at least around 250hp, 320tq
L48 350
Holley 670 Street Avenger Carb
Edelbrock Performer EPS 2701 Intake
1 5/8 3in collector Hooker Headers
Crane 274H06 cam, .450 lift, 274 duration, 106 lobe separation
Stock heads
Stock bottom end
Thanks for your time
L48 350
Stock heads
Stock bottom end
L48 350
Stock heads
Stock bottom end
L48 350
Stock heads
Stock bottom end
Good luck, Chris
