1977 turn signal/wiper lever
thank you that's great. That's the first time something actually was as easy as it looked, unfortunately my luck never follows suit lol. My turn signals work but wipers do not. I believe it could be the ground that would come down thru the fire wall into the car because I have a couple ground not connected by my radio area. One of them off coarse is for the missing radio. I don't want to just start connecting stuff and make matters worse. Any suggestions
Here are a couple of links.
Wiring schematic:
http://repairs.willcoxcorvette.com/1...tic-1977-only/
Bench Test:
http://repairs.willcoxcorvette.com/1...d-wiper-motor/
Here's another question....
Did you check the 25A fuse labeled "Wiper" on the lower right of your fuse panel?
The yellow wire on the wiper motor plug should have 12 volts when the key is in the 'ON' position regardless of the position of the wiper / washer switch.
