air condition lines
Carefully. Have the system evacuated, (unless the Freon has already leaked out), and then remove the lines for the evaporator/condenser, and accumulator. The trick is they may be frozen in place. Dissimilar metals corrosion. Use double wrenches on everything. It may take some heat to get them broken loose. I would suggest replacing the accumulator and orifice along with all of the O-rings.
blue1982 (10-06-2017)
are you staying with r12 or are you changing to 134?if going with 134 you need to use the green orings.I took my hood off to replace the front line.
