1979 L48 with manual trans changing the clutch
Old 10-13-2017, 12:00 PM
r16678
r16678's Avatar
Default 1979 L48 with manual trans changing the clutch
I have a 1979 L48 and I am changing the clutch, flywheel, throw out bearing, and pressure plate. I did not see a pilot bearing, is there a pilot bearing in this setup, if so where is it installed and where can I get one. Thanks for all your help
Had one more question, when tightening down the bolts to attach the fly wheel, is there a trick to keeping the motor from turning besides putting a socket on the front crank pulley?
Old 10-13-2017, 12:23 PM
71VetteLover
71VetteLover's Avatar
The pilot bushing is pressed into the rear of the crankshaft.
r16678 (10-13-2017)
Old 10-13-2017, 12:38 PM
Rodnok1
Rodnok1's Avatar
Pilot bushing should be changed every clutch change, might as well since have apart and cheap.
They make a flywheel holder/turner you can use to hold it, I've jammed long screw drivers against flywheel ring to stop from turning before.
r16678 (10-13-2017)
Old 10-13-2017, 01:35 PM
croaker
croaker's Avatar
Do your research on the correct pilot because they will try to sell you the roller one. The guy at Napa argued with me about it. I lucked up and found one at my Orielys.
r16678 (10-13-2017)
Old 10-13-2017, 01:44 PM
Frankenvette
Frankenvette's Avatar
Changed out pilot bearing during tranny swap. I read up on the easiest way to remove pilot bearing. Lots of different techniques. I used the white bread method and damn if it did not work.
r16678 (10-13-2017)
Old 10-13-2017, 01:48 PM
Revi
Revi's Avatar
Various auto part stores will also "rent" you(sometimes free) a Pilot Bearing Puller.
Agree with above, don't use a roller bearing type pilot bearing. Just use the tried and true bronze one.
r16678 (10-13-2017)
Old 10-13-2017, 02:43 PM
71VetteLover
"The white bread method"? Is that like using a heavy grease and using hydraulic pressure to push it out? In the past I have tapped them then used a long screw to force it out when the screw bottoms out.
r16678 (10-13-2017)
Old 10-13-2017, 03:05 PM
Frankenvette
I literally used white bread, kept packing until the bearing was forced out under pressure.
You can find it on You Tube.
r16678 (10-13-2017)
Old 10-13-2017, 03:10 PM
JoeMinnesota
JoeMinnesota's Avatar
Pilot bearing is sunk in the center rear of the crankshaft. You can see it once you pull the pressure plate. I have a machined install tool/punch and pack my bearings with grease and then tap the tooling in to force the bearing out. Several methods to try.
As mentioned above, USE THE SOLID BRONZE BEARING.
To hold the flywheel, I wrap a rag on a spot in the ring gear and clamp on a set of vice grips, which can be wedged against a bellhousing dowel or a bolt temporarily screwed into the block. Works just fine.
Old 10-13-2017, 05:52 PM
r16678
r16678's Avatar
do you know if there is video on the install or some pictures with instructions. Appreciate everyone's help
Old 10-13-2017, 06:33 PM
Matt81
Matt81's Avatar
When I did my TKO600 swap, I jammed playdoh into the pilot bushing, then used a 3/8" ratchet extension. Pressed it onto the playdoh, then tapped with a hammer. Bushing popped right out.
r16678 (10-15-2017)
Old 10-13-2017, 11:42 PM
gkull
gkull's Avatar
Received 1,329 Likes on 1,057 Posts
Why are you against roller bearings. If you think about it a properly dialed in bell housings. The tranny input shaft should never touch the pilot bearing
Old 10-14-2017, 12:19 AM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
tried that grease and bread deal just made a mess & pizzed me off
Op make sure the new one fits over your input shaft before reinstalling
r16678 (10-15-2017)
Old 10-14-2017, 03:35 AM
hunt4cleanair
hunt4cleanair's Avatar
So is your transmission a cast iron or aluminum case? Some 79 L48s were shipped with the Saginaw Munce M20. In which case, you may come across parts availability limitations.
The 78/79 Muncie Four-Speed
r16678 (10-15-2017)
Old 10-14-2017, 04:27 AM
croaker
croaker's Avatar
I try to use the Kiss way of thinking. Roller has more parts to go bad. Plus how could all those GM engineers not be right
r16678 (10-15-2017)
Old 10-14-2017, 07:55 AM
jb78L-82
jb78L-82's Avatar
L-48's did not come with the super T-10 close ratio 4 speeds (the L-82's), only the wide ratio sagninaw's, as far as I know. The L-48 2.85 Low first gear tranny's are Saginaws
Old 10-14-2017, 10:06 AM
gkull
gkull's Avatar
The engineer is over written by the bean counters.
Roller rockers, roller lifters, floating pin pistons, and roller bearing cam shafts. Have much less mechanical friction loss
Because grandpa cut off the top of a valve cover to adjust the valves doesn't mean that is the best valve train or adjustment method
The roller is supior
r16678 (10-15-2017)
To 1979 L48 with manual trans changing the clutch
Old 10-14-2017, 05:10 PM
Revi
Revi's Avatar
What exactly is the gain of using a roller bearing over a bronze? Superior in what, friction? Can you provide a HP or performance gain/loss between the two?
A roller bearing can/will fail into numerous parts and trying to remove just the outer race is a b1tch. The old bread/grease trick will not work. A bronze bearing may wear, but it doesn't break apart into pieces.
Any performance/wear differences between the two is minuscule compared to having to replace a failed roller bearing. Moving parts (roller bearing) fail far more than non moving (bronze) parts.
I've never had a bronze bearing fail on me, I can't say the same for a roller bearing.
Old 10-14-2017, 11:33 PM
gkull
gkull's Avatar
What if I said that in my life neither one or kind has failed with perfectly dialed in bell housings. So removal wasn't a problem
If you have a centered tranny input shaft and dump the clutch on a high hp quality motor it might have the ability to tq bend the shaft into the crank bearing
All the high quality motors I have built at the shop get roller parts including my own tko 600
r16678 (10-15-2017)
Old 10-15-2017, 10:32 PM
r16678
r16678's Avatar
Thanks I have a super T10
Quick Reply: 1979 L48 with manual trans changing the clutch
