2nd Tach filter behind the dash? Or what is this?
So I'm attempting to fix my tachometer. I had previously removed this filter which was attached by the distributor to test if that was the problem
And then today I was attempting to take the dash apart so I could replace the tach board. As i got the dash pad off - I noticed this. It looks like the same filter, but it's behind my gauges and sitting against my steering column. Is this a second tach filter? It's connected to a brown wire, which is the same color as the connector to the tach
