tubular a-arms
Old 06-07-2018, 10:02 AM
  #41
Primoz
CF Senior Member
2017 C3 of Year Finalist
This arrived today:
Can't wait to get going!
Primoz is online now
Old 06-11-2018, 04:29 AM
  #42
ToniH
CF Senior Member
ToniH's Avatar
I too have a set of these Impala arms waiting for test fitting. Also lowers. Don't know when I get the time but will post when I do.
Also, I haven't checked yet if the poly spring pocket on the lowers is compatible with VBP 550 springs or if I need to source new ones from somewhere.
One thing I can say straight away: I also have a set of old VBP uppers and they seem flimsy compared to these. I mean paint was chipping off the welds due flexing after one summer. These seem more massive and better gusseted to me. Time will tell if I judged them correctly by looks only.
I was originally planning to get the Global west arms but he never replied to my email so I took a risk and bought these instead. Atleast they were so affordable I can get my money back locally from Impala guys if they do not fit properly.
ToniH is offline
The Following 2 Users Say Thank You to ToniH For This Useful Post:
Primoz (06-11-2018), worship79 (07-31-2018)
Old 07-30-2018, 07:27 PM
  #43
sunflower 1972
CF Senior Member
sunflower 1972's Avatar
@Primož Krajcar, just wondering, any update?
sunflower 1972 is offline
Old 07-30-2018, 08:06 PM
  #44
naramlee
CF Senior Member
naramlee's Avatar
holy crap, are you serious?! this is what ive been looking for!!!!
naramlee is offline
Old 07-31-2018, 05:26 AM
  #45
Primoz
CF Senior Member
Hi!
Sorry nothing yet! We just tried it on my friends 64 with 427 engine, because the chasis is the same as C3 and they look like they fit with no problem.
I will take my car out in the following days. My battery died and I'm waiting on the new one. I don't want to push the car out of the garage by hands!
The Following User Says Thank You to Primoz For This Useful Post:
sagebrush rebel (08-02-2018)
Old 08-01-2018, 05:51 AM
  #46
bmans vette
CF Senior Member
Support Corvetteforum!
bmans vette's Avatar
St. Jude Donor '12-'13, '15- '16-'17-'18-'19
Following this thread......great info guys.....
Thanks!
bmans vette is offline
Old 08-04-2018, 12:22 AM
  #47
naramlee
CF Senior Member
naramlee's Avatar
Thanks!
im about to buy these... waiting be damned for these price I don't mind gambling
naramlee is offline
Old 08-04-2018, 06:28 PM
  #48
TCracingCA
CF Senior Member
Heck you could go with a theme! Get some Impala emblems, interior upholstery, until you drop your dual quad 409!
TCracingCA is offline
Old 08-05-2018, 09:16 AM
  #49
JoeC427
CF Senior Member
JoeC427's Avatar
Originally Posted by terrys6t8roadster View Post
Those look like some nice pieces, thanks for posting. T
+1
Those uppers look cool...
JoeC427 is offline
Old 08-11-2018, 04:41 PM
  #50
Aquarian
CF Senior Member
thanks for the info...still have the front cap off...now would be the time..
Aquarian is offline
Old 08-13-2018, 12:37 PM
  #51
AGrey
Junior Member
Hard to tell with just a picture, but the 55-57 Bel Air lowers look very similar to the corvettes...
https://www.jegs.com/i/JEGS/555/64566/10002/-1
Then this setup would make life easy:
https://www.performanceonline.com/19...n-kit-stage-3/
AGrey is offline
Old 08-13-2018, 03:47 PM
  #52
sunflower 1972
CF Senior Member
I found these and ordered them:https://www.ebay.com/itm/For-1958-19...6d32%7Ciid%3A1
Just finished installing the drivers side. The only issue I had was the control arm shaft mounting holes are about 3/16's of an inch too wide. After slotting one of the holes with a die grinder (about 45minutes) to accommodate the narrower C3 control arm mounting studs, the arm slid right on.
NO CORVETTE TAX AND FREE SHIPPING!!!
The Following User Says Thank You to sunflower 1972 For This Useful Post:
Primoz (08-13-2018)
Old 08-13-2018, 03:58 PM
  #53
Primoz
CF Senior Member
Good job installing them! Any issues? Other than grinding a bit?
Old 08-13-2018, 04:06 PM
  #54
sunflower 1972
CF Senior Member
Nope, none what so ever. And thank you for coming up with the old Impala control arm idea.
Old 08-13-2018, 04:15 PM
  #55
Primoz
CF Senior Member
No problem. Thank a guy in the video for sparking the interest in me for doing the research. Now I really have to install mine asap!
Old 08-14-2018, 02:34 AM
  #56
bmans vette
CF Senior Member
Great pics and info.
It looks like you were able to install delrin bushings in with the cross shafts.
Correct?
Did they come with the a-arms or did you buy them separately?
Item title and part number along with source would be most helpful.
Thanks again.
Are you planning a follow up pic after alignment? And are you doing alignment yourself?
Thanks again
Bman (Dennis)
Old 08-15-2018, 01:22 AM
  #57
naramlee
CF Senior Member
naramlee's Avatar
I wouldn't use those because the lower control arm mounting points are different, don't know what else is different either
I just ordered the impala kit as well, figured it's time to do it and the borgeson swap while the engine is out
thanks for taking the plunge for us all sunflower!
dang those cross-shafts are beefy... well I wont have any hesitations about slotting them for castor gains... those things look like an inch thick...
did you have to replace the bushings? or did they come with Delrin?
naramlee is offline
The Following User Says Thank You to naramlee For This Useful Post:
bmans vette (08-15-2018)
Old 08-15-2018, 05:20 AM
  #58
Primoz
CF Senior Member
Well the lower arms from Impala have different mounting points for the sway bar so you have to change those to make it work.
The Delrin bushings and ball joints come with the arms.
Old 08-15-2018, 12:34 PM
  #59
naramlee
CF Senior Member
naramlee's Avatar
yeah i knew that about the sway bar mounts, but the other arms have 4 bolts vs 3 on the from mount points according to that picture
naramlee is offline
Old 08-15-2018, 02:46 PM
  #60
sunflower 1972
CF Senior Member
Correct?
Thanks again.
Thanks again
Bman (Dennis)
The arms came complete with the beefy shafts and Del-a-lum bushings and ball joint installed.
Hot link where I purchased:https://www.ebay.com/itm/For-1958-19...6d32%7Ciid%3A1
I will align the front myself. I have a camber/caster gauge and square aluminum bar stock I use as makeshift
toe plates. Yeah, I can post a photo after I align it.
I did ask the place I bought the arms from if they could tell me how much more positive caster they provide and they replied they did not know. By the looks of them it appears to me like at least 4* positive caster, but I'll check it with my camber/caster gauge and post the findings.
Quick Reply: tubular a-arms
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
