The Easiest Way To Bump An Engine Over
About 5 years ago I was adjusting my lifter pre-loads one evening when I realized there had to be a better way to bump my engine over than using my key switch. So I ran a 12 gauge (green) wire from my starter solenoid's "S" terminal up to my air restriction indicator's mount bracket and by connecting my Snap-On push button switch's leads to the bracket and to the HOT stud on my BUSS fuse block I can bump it over just a few degrees at a time by tapping the button on a hard surface.
Heck, it only takes a few minutes to jack your C3 up and connect an additional wire to your solenoid's "S" terminal so I suggest doing it as soon as you are able. As the firewall is fiberglass you can end the wire anywhere to the left side of your firewall and above your valve cover then you can use that to bump your engine over without the fear of it starting because your key switch would still be turned OFF.
It's these "little things" that make life so much easier.
I put my car in 1st gear and rock it a bit to rotate the crank. I find it more accurate this way to get the 90 degree marks spot-on. But if your car is an automatic, my method doesn't work so well. :-)
jim-81 (10-27-2017)
That'll work but it works much better in 4th gear because the engine turns so much slower. When the rear tires turn one revolution in 1st gear the engine will turn about ten times whereas in 4th gear it only turns once. And it takes a lot less effort to nudge it foreword or backward when it's in 4th gear.
jim-81 (10-27-2017)
If it's an auto and you don't mind pulling lower flexplate cover, this tool works great. Lisle Flywheel Tuners 23800. https://www.summitracing.com/parts/l...CABEgIBtvD_BwE I use mine a lot when I need to rotate the motor at 90* increments.
You can connect to the purple wire with a white strip either under the dash, (automatic), or in the front of the console (manual) with a 10-12ga wire, run that under the hood to someplace accessible, and hook a remote button to that. And never have to go under the car.
This last summer I suddenly began having "no crank" issues after I had driven 40 to 50 miles and with an outside temperature of over 100 degrees; leaving me wondering how on earth I could get my engine started when I was a long way from home. Then I remembered I had my under hood "method" to crank my engine so I popped my hood, turned my key ON, then shorted across the connections and BINGO...........my engine was running again. Yippee! It turned out I had a bad purple solenoid wire connection coming off my neutral safety switch so I butt-connected the wires together; eliminating the male/female plug that wasn't making a good contact. So my under hood method saved me from having to be towed 40+ miles.
Lordy
