Fuel leak in cold weather
Cruising
The cold weather finally hit Minnesota this week (30s). I filled the gas tank and parked my 74 BB for the winter and now notice a fuel leak. It seems to be coming either from the upper hose into the fuel pump or the fuel pump itself. This happened last winter as well. I bought hoses and pump, but then this spring, no more leak.
Does anybody else have a winter leak? I am going to replace everything, but was curious as to anybody else running into this issue.
have you tried tightening the hose clamps?
Received 2,125 Likes
I really doubt temps have anything to do with the leak. I bet the leak was always there. But when things were hot out you had more evaporation, leak was less noticable.
Time for new hoses. Purchase the good stuff that is compatable with that lousy Ethanol. Get new clamps too. The kind that require a nutdriver or socket to torque instead of a screwdriver. If you put the front end up on ramps the fuel supply line is not as likely to drain on your face when changing.
Does the B.B. require an special "S" hose like the SBC at the fuel pump? If so, buy it don't make it.
Negative on the longer route. You must have bought a knock-off. A quality "S" hose should last for several years. (Mine is 8, no cracks) Too many C3 owners try to make their own "S" hose and fail. You must use a preformed, correct dia, correct length, Ethanol safe hose.
