69 LS3/Tremec 6sp Hydraulic Clutch Question
Anyone out there have experience with addressing the installation of a hydraulic clutch to accommodate the Tremec trans hyd throw out bearing? I have a 69 Vette that I'm installing a LS3 500hp engine and Tremec Magnum 6sp trans. Thanks in advance for your input to my question!
Also consider a twin disc vs single, it will make it feel like a C6 transmission with a much lighter pedal. My notes I used a single disc and changed to a twin disc.
Single disc with high torque ratings is very heavy pedal feel vs better torque rating of a twin disc.
https://www.corvetteforum.com/forums...-corvette.html
I used the 2002 Camaro hydraulic throw out. Bolted on the T56. No shinning required. LS7 flywheel and clutch.
My LS3 did 420 RWHP. Has a small cam. Never a problem with the clutch holding.
Nice easy pedal feel. Also have the speed bleeder from Tick. Makes the bleeding fool proof.
American powertrain HMGM-01201G kit,
https://www.summitracing.com/int/par...201g/overview/
and mounted in the factory location ( see my link in my post above I have pictures of the mounting)
I also reversed the safety switch and rod locations on the clutch pedal to get a better ratio. Never did get 6:1 but very close. (modified mounting on the clutch pedal)
the HMGM-01201G kit has a adjustable mounting plate to the firewall to allow for different angles required.
Not the same year or engine but the same transmission. This is my conversion from auto to manual (T56 Magnum)
Thank you so much for your post....this is exactly what I was looking to include necessary details, modifications required and pictures!!! I assume my 69 will be a little easier being an original 4 speed car. Do you know if there are any differences between the trans tunnel compared to yours! Please advise!
1rad55 (11-12-2017)
