tilt/ telescopic steeing column
1973 vette
Jonsz06,
You never mentioned what year C3 that you own also if you have a standard (non-adjustable) steering column or a Tilt & Telescoping type.
There was a Z07 Off Road Suspension and Brake Package available from 1973 through 1975 but there was never a Z06 option available for any C3. So your Corvette Forum name doesn't help.
The type of steering column is important because the head portion of the standard column versus the T&T type is very different.
All GM vehicles with locking steering columns had lock cylinders that had the following five positions: START, RUN, OFF, OFF-LOCK, and ACCESSORY.
Also, the 1969 through 1976 C3 steering columns had a lever on the lower end of the steering column (out in the engine compartment) that attached to a cable coming from the vehicle transmission. You had to be in PARK (auto trans) or in REVERSE (manual trans) in order to rotate your ignition lock cylinder and key from OFF to OFF-LOCK.
The 1977 model year there was a basic steering column change that affected all 1977 through 1982 Vettes. The cable was eliminated and a small lever was added to the steering column head, right behind the ignition key and lock cylinder. You had to trip the lever with your finger in order to be able to rotate the lock cylinder from OFF to OFF-LOCK.
Supply some more information and possibly I can help.
Jim
Jim
My car is a 1973 Vette with tilt and telescoping steering column. It has a 4 speed transmission.I changed the ignition because I had no key so that's how far I tore the column apart. Now it won't lock.
I don't know how to proceed.
Thanks for any suggestions you can send my way.
John
Hi Jim.
John
John
Many old Vettes (1969 thru 1976) may no longer have that transmission to steering column cable. Header pipes, corrosion, heat, and age could have caused the cable to become disconnected. In that case, the lever on the lower end of the steering column should be permanently positioned at that 1 o'clock position. The lever permanently wired in place.
steering column
[QUOTE=Jim Shea;1596029592]Jonsz06,
eerQUOTE]
The lock cable works. The steering column - the telescopic part does not lock, in other words, the steering column keeps going in and out, I can't get it to lock in place.
eerQUOTE]
