front vs rear wheel-to-brake clearance, which is closer?
I'm going to mock up a C3 hub assembly to check aftermarket wheel clearances.
Which has the tightest go/no-go clearances, front or rear?
Thanks in advance
Thanks in advance
are you referring to the wheel mounting surface versus the sides of the brake caliper or some other measurement?
they need to be at least 15" in diameter but you need someone to measure the wheel mounting surface to caliper distance on a corvette and then compare that to the wheel to make sure the spokes of the wheel dont hit the caliper sides.
The manufacturer doesnt provide a application guide?
Seems like they will need to be put on and checked. I have a few customers with the old school wheels and some use the spacers with extended wheel studs and others have special adapter hubs made.
DUB
DUB
