Help on adjusting 82 T-Tops
My tops need to be lowered a bit. I figured out how to remove the shims from brackets that slide into the middle bar but how do you adjust the side by the widow with the latch?
Thanks for the help!
Received 1,468 Likes
Cruise-In II Veteran
The receivers on the halo panel have a little bit of adjustment. Loosen but do not remove the mounting screws. There may also be some sealant under the mounting plates.
If your tops are glass, keep in mind the glass tops sit higher at the halo panel than the fiberglass tops. Follow the AIM instructions and do not attempt to get the glass tops flush.
