fuel filter for rochester carb
if your car has a fuel return line to the tank and you do not use a filter with a check valve your Q jet the float bowl will drain down and cause hard starting.
Had a 1976 L-82, 4-sp
Location: Some days your the dog and some days your the hydrant.
Received 1,199 Likes
Royal Canadian Navy
My '76 had the filter removed from the QJ and an inline gas filter installed between the carb and fuel pump using two pieces of rubber tubing and four gear clamps. Never had any problems. Lots of guys do this simple mod with a caution to not use the glass type inline filters.
tixeon (07-14-2019)
