My 454 build. What do you guys think.
That cam will work great. Definitely make sure you put a mild converter in it though.... 229/241 may be a bit much for the stock converter for a smooth idle in gear.
With the right converter and that cam and some compression, it'll be a stout 454.... A great street motor.
My modifications are based around using a very competent machine shop
.060 bore
Zero deck
Mahle 28 cc piston dome cut down/or not based on your altitude
1.880/2.190 valves
Index and set stroke 4.00, cut 1/2 off counter weights
Isky 218/228 hyd roller
Performer air gap intake
QF 850 vac sec
This will work with your stock converter, and I might add it will hit it like a savage
.060 bore
Zero deck
1.880/2.190 valves
QF 850 vac sec
I actually built this exact same engine using a core like the OP's. Idle was a nice 750 RPM which would work good with the stock converter, 12 inches of vacuum @ 6400 feet elevation, although the cam was 228/238 on a 111 and the carb was a 1000 AED, the piston domes were cut down for a 9.8 compression, the the specs above apply. A very nice mild engine! Looks kinda innocent.....
Dr. Detroit
Received 3,892 Likes
https://youtu.be/OzkaP2sSipw
Jebby
[QUOTE=Vortecpro;1596440926]I tried to tell the OP he had the parts to make it happen. You don't have to have a chinesse stroker crank and rods to make power.[/
Mark can I ship you my 781’s?
