C3 1982 Collector Edition Power Antenna Relay Location
Hello all,
I'm trying to find the Power Antenna Relay Location in my 1982 C3 Collector Edition.
The problem I have is the antenna mast is stick in the up position...I'm not sure if the problem is related to the relay or if I have an issue within the power antenna itself.
Can anyone kindly offer any past experience on how to diagnose where the fault is?
If I can I'm trying to avoid removing the antenna, as this is quite a process involving the removal of the muffler.
As always, many thanks in advance.
Cheers,
Artie
Cheers,
Artie
If my memory serves me correctly...the power antenna relay will either be behind the passenger seat...under the pull out tray in the compartment behind the passenger seat.
It is mounted on the backside of the vertical panel that your seat back rests against when the seat is all the way back. You about have to get your head upside down to look
in and see it.....OR...it is bolted to the underside area of the hand brake cover on the passenger side. Removing the carpeted side console strip will let you see it.
There relay will have two wire connectors plugged into it. And each of them will have 3 wires in each of them I know one of the connectors will have a green, white and gray wire in it. That connector is coming from your antenna....and the other I believe has an orange, pink and black wires in it.
DUB
DUB
Artie NutZ (12-13-2017)
sorry but most likely you will have to remove the antenna.i would check to see if it is getting power,but generaly its the plastic cable that breaks.for me I would not replace because it will break again.leave it alone and replace with a hidden antenna.
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The antenna is more often the issue.
You'll find the relay here:
DUB
DUB
If the white antenna mast cable has snapped..the antenna will run until it kills your battery.
DUB
