79 - thermostat housing gasket or o-ring?
Red Ryder (09-27-2019)
with drilling a small hole in the thermostat itself.
It allows the trapped air to burp out of the engine block while it is running so you do not have to wait for the thermostat open when filling it.
And this small hole does NOT effect any of your cooling proprieties at all. So no fear of your engine all of a sudden beginning to overheat.
DUB
DUB
DUB
DUB
Just wondering, I've never done it but I have heard of people filling the block directly, and if you've already got the thermostat housing off and replacing the gasket, why not?
I have a question similar to the OP, I'm fault finding a coolant leak and pulled my thermostat to check (it seems fine). Here in Australia I sourced the following gaskets and o-ring at my local auto parts store, but not sure if I should use sealant as well.
My housing has a groove for the o-ring, and I have a paper gasket as well which has adhesive on one side. The gasket sealant I bought is Permatex Fuel Resistant Gasket Sealant - 85420 as they didn't have the dedicated water pump/thermostat housing sealant.
Thoughts?
Based on the pictures, I would just clean the housing and manifold - then grease the o ring with dielectric grease and assemble the water neck.
I have always drilled a 1/16 to 3/32" hole in the thermostat for 2 reasons:
1 - to get the air out
2 - to keep the water moving, it lessens the shock of a closed thermostat suddenly opening and especially with AL manifolds or heads reduces the temperature spike / shock. It does not affect the temperature of the motor.
OzBeast (01-01-2018)
Received 2,112 Likes
YES, dielectric grease. It will not attack the O ring and it will allow it to properly seat. The grease is not for sealing.
That is the same reason it is recommended (by GM and other manufacturers) for the weather-stripping on the C3 T Tops, C4 - 5- 6 & 7 . It solved my squeaking when I run my C4 on a winding road / course. Solved the leak on my truck with the "chrome water neck" and now I can change thermostats without replacing the O ring.
Couldn't you just fill the block with coolant through the thermostat opening before replacing the thermostat and housing? Then fill the radiator per normal.
DUB
DUB
BLUE1972 (12-30-2017)
