1977 Early or Late TTop Seal identification needed with pics
Need new top seals for the 1977. Door sicker says mfg date is early (10/1976) and the VIN numbers at the end are 406578, making it the 6,578 unit to roll off the line, also way early. Alarm is on the fender but I do sport a blue motor
I am hoping someone can identify the seal itself by the following pics. I am assuming it is the early design... Any help? Thanks, Jim
As for the metal strip, that's where my confusion is. There is a piece of metal that looks to be behind the rubber in the seal (see pictures 1 and 2) and there also appears to be a zig zag piece of thin metal in there as well ( the rubber I assume was torn off).
Thanks Jim
And Merry Christmas to all. Hoping you reflect on the gift of Christ tomorrow.
It was an early design
Is it possible to count the pins (19 early, 18 later) without removing the current seal?
Thanks Jim
Thanks Jim
I used the 3m black weather strip adhesive with good luck.
That's it - just closing this thread. Jim
jimvette999 (01-05-2018)
