78 C3 Cruise control - Speedometer
When I got the C3 it did not have Cruise control or A/C for that matter.
upon installing the CC, my main concern was just getting the parts needed and getting connected. Now that I am able to drive it I would like to get this corrected.
1) I find when driving I seem to be slower than everyone else. I had the wife keep pace and report her speed via blue tooth phone at several increments. 50. 60, 70, ect. At 50 I am doing 42, at 60 I am doing 54, at 70 I am doing 66 about 3500 rpms. At 80 I am doing 78.
SHOULD not this be the same 50 is 50, 60 is 60??? and what would cause the diff.??
2) the cruise control button on the tilt column dose not engage the CC unit.
My thoughts are there is not enough vacuum and I need to install a small vacuum unit to in line to help with that.
from what I read and see, there is such a unit used, also some mention of adjustment? on the transducer??
do you have the stock diameter tires on the car, 27"?
has your rear end gear ratio been changed from stock?
You install the correct gears in the tranny to make the ODOMETER read true. THEN, you calibrate the speedo head to match that.
Most heads this age will need re-magnatizing to correct this.
I just had mine calibrated. $45.
Tire is 27" % of change from orig. -1.3
I got to thinking after I wrote, speed is determined by the gear in the trans. tires and R-End. not he transducer.
And if it is light while driving that may be a good thing, can not over speed and get a ticket.
DB
I am guessing it is one with a dyno??
Can it be calibrated with out the CC working????
i'll bet you have to remove the speedometer from the car to calibrate it and how do you know the rear end gears havent been changed?
I think Willcox does speedo calibrations. Wrt to finding your true moving speed, a ... uh ... windshield mounted GPS unit will be of more use since it does report speed quite accurately.
I have one here in Anaheim.
714-535-6471 Precision Speedometer.
