G'day All,
Bought myself a used TKO 500 for my '69 SB L46 (nom) with 4 speed
muncie. I'm trying to source a new quick release slip yoke, but I'm not sure
whether I require one for 1350 or 1310 uni joints. Can someone enlighten me.
A 1350 slip yoke will likely cause you clearance issues. The factory 1310 style yoke will fit no problem. There is a 1330 slip yoke that is no longer made but it fits the tunnel if you can find one. Factory yokes are 26/27 spline which works with a T56 but Im not sure about the TKO 500. Ft. Wayne Clutch will take good care of you, but any good drive line shop should be able to source the parts you'll need.
