467 650 HP Pump Gas Build ?
#44
I looked at Vortecpro's website--- I built my 496 and spent just a little more than his prices. But if I take out the stuff I added on-- .904 lifters (and the machine work to install bronze bushings) and the T&D shaft rockers, it's close enough on cost to not make a difference. And all I got was a big pile of parts. Vortecpro is ready to drop in and fire it up.
#46
Received 1,875 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I get a kick out of seeing Alan's car in the magazine article I did in the background!
BTW...I told the editor to call you for some quotes on another article he's doing....
JIM
JIM
ajrothm (01-14-2018)
#47
Your writing is second to none........and I mean that. Hot Rod and Car Craft would be a much better publication with you at the helm. You were good Frieburger but you just don't have Jims hard core race experience.
#48
Ready to dyno........it ain't no peanut port this time. I will see if I can get Harold to graph this 467 over my peanut port, so we can see what moving the power up will do for track times.
#50
You know...you've just about got those things figured out!!! Wow......sounds sweet! CK out that oil pressure.......
Some 396 decals and a 4 speed with some 4.56's and 29"-30" tires would be a blast!!
Come out HARD and bang some gears with a little oval port flat tappet!!
JIM
JIM
#51
DAMN! 670hp with only 467" and a flat tappet....with a dual plane intake spinning to 7k....-- This **** is gonna shut the internet down.
I hope you don't retire before I need my next motor....
#52
That is very impressive for what is there. And an oval port cast head to boot.
My last 468 went like this.
2 bolt main block studded
12.5-1 compression, with a 6.385 rod
Balanced blue printed etc all the good machine shop stuff.
Cam Motion solid roller, .692/.684 with .262/.272 @ .050 on a 112LSA Nitrous friendly
Heads were out of the box AFR 305 rec ports.
Vic Jr Intake and a 950 hp holley 2" Hooker header.
Dyno said
708 HP 622 TQ on the Motor.
1006 Hp 1095 TQ On Nitrous.
So For all the extra money i spent on heads and roller cam plus compression i only gained another 30 hp on the motor over your combo and i was not pump gas friendly unless i backed a bunch of timing out .
#53
#54
Now lets compare this engine in this thread (620 467) to a known 467 that has been run in my 1968 Chevelle @ a known weight of 3720 pounds. The engine specs with a graph comparing the two engines below, the lower graph depicts this engine run @ 3720 in 28.95 barometer, 10.34 @ 126.1 MPH, the upper graph depicts the engine in this thread.
467
236 peanut port heads
228 @ .050 hyd cam
Stamped steel rockers
1.250 valve springs
9.3 actual compression
Performer RPM intake
AED 850 carb 1 inch spacer
Performance:
10.34 @ 126.1 @ 3720 in a 28.95 barometer
467
228 @ .050 hyd cam
1.250 valve springs
Performance:
