Can't We All Just Get Along
Likely differences in AF ratio per cylinder. Could be a leak in the valve seat, but doubtful. Probably the difference in AF that the intake manifold is presenting to each cylinder. It is probably fine and unless you are looking to spend a ton of cash equalizing things, I would run it as is.
A white exhaust valve along with piston top is a good sign of a small head gasket leak and the white coating is a result of burning antifreeze. Have you checked your coolant level? Burning antifreeze leaves a white residue like that as long as the cylinder is still firing.
Received 1,468 Likes
Cruise-In II Veteran
Why post twice?
https://www.corvetteforum.com/forums...s-picture.html
The following 2 users liked this post by BKarol:
imariver (01-05-2018),
Torqued Off (01-05-2018)
What intake manifold is on the engine? Interesting that 4 cylinders are "fat" and the others are "lean"....
Received 2,878 Likes
Hi imar,
We could certainly be more civil with each other!
People have questions....and they deserve answers.
Regards,
Alan
Regards,
Alan
PainfullySlow (01-05-2018)
The engine is the original numbers matching L-48, never been out of the car and the odometer shows 129 K miles. It still has it's original intake and all rotating parts are original too.
However, in Feb. 2016, I replaced the (original) heads with a set of 041 heads. Since that time, I have never had a coolant issue, no leaks external or internal. The fluid level in the overflow jug, has always remained the same.
I don't often post on these boards, but when I do, I'm seeking advice and information from those that have more knowledge and experience than me and the last thing I need, (or want) is to be confronted. After all, the advice posted, benefits everyone.
Received 2,124 Likes
Somewhere on the internet is a drawing of an SBC intake manifold showing which cylinders are fed from the top chamber side of the intake plenum and which are fed from the bottom chamber. This would be on a dual plane of course.
I bet that the secondary jets are either not functioning well due to a low float level, plugged secondary metering block or the secondary throttle plates are closed shut at idle. Did you play with the secondary adjustment screw under the Holley by chance?
St. Jude Donor '22
the white reminds me of shell gasoline
every time i ran shell, i had white soot on my plugs.
not uncommon that some manifolds
on some engines have a rich and lean side.
different jets are not unheard of.
the white looks cleaner.
the valve stroke is clear.
both valves are on the edge.
a little too dark on one and a little too white on the other.
if the white was around the head of the valve only,
I would say ok.
tough call.
check the valve seals and guide wear.
I would say ok.
tough call.
Steve, I saw you recently did a few dyno pulls. Was everything OK at that time or was there some indication of problems, such as a miss or A/F ratio being off? Is that perhaps why you're poking around or is this more of a random inspection? The white being on the valve only has me mystified. Everything around it and in the next door port looks normal in color to me.
Nam Labrat
Received 4,173 Likes
Wondering: Is the valve seating?
