Global West "extended" lower control arms...
Old 01-05-2018, 04:00 PM
BlackRocket
BlackRocket's Avatar
Default Global West "extended" lower control arms...
Has anyone tried these extended lower control arms?
http://www.globalwest.net/corvette-f...lover-c-3.html
I spoke with the company and they stated that the extended arms lower the front of the vehicle 2" while allowing full travel of a coilover. The rep also stated that with their standard lower control arms the ride height can be lowered 1-1.5" but will lose shock travel. I am not sure they will clear my 18x8/4.5 backspace with P245/45's?
Looks really close!
Thanks, B-R
Old 01-05-2018, 05:20 PM
69ttop502
69ttop502's Avatar
I have them but am body off restoring the car right now. Just hung them on the chassis a couple days ago. Really nice stuff. Going to run Ridetech coilovers with them. I am running the Ridetech system in the rear but didn’t do the front mainly because I am staying with 15 inch road race style wheels and tires and want my stock brakes and already had Wilwood D8 6 calipers. Got the Global upper arms also. Really beefy, strong arms. Definitely heavier than stock stuff, and I hear their bushings are the best around. Sorry I can’t give you any driving feedback yet.
Bill
Old 01-05-2018, 06:27 PM
Neil B
Neil B's Avatar
Hmmm. Those look interesting. I don't like the mandatory brake upgrade with the Ridetech arms. What I did for now is I custom ordered threaded body Viking shocks with poly lower mount and mounted them on the bottom of the stock control arm. You can do this with a regular lowered coil spring but not the semi coil over. It would be easy to use these same shocks and upgrade to the GW arms. Excuse the dirt this is still work-in-progress.
Old 01-05-2018, 07:28 PM
Metalhead140
Metalhead140's Avatar
C3 of Year Finalist (track prepared) 2019
I think from memory that craigh has these and has some discussion of them in his build thread?
Neil, I'd recommend running longer bolts with additional nuts above the control arm - I stripped some of those threads on my lower arms using Bilstein Sports.
Old 01-05-2018, 07:38 PM
Neil B
Neil B's Avatar
Will do. That was just a mock up.
Old 01-05-2018, 08:22 PM
Kid Vette
Kid Vette's Avatar
Looks really close!
Thanks, B-R
I think you misunderstood what the tech was saying. These A-arms don't automatically lower your car 2". They allow you to lower it 2" and still have full travel of the coilover. The ride height is set with the coilover; not the A-arm. "The shock is mounted lower in the control arm extending the shock length so there is more travel at the lowered ride height."
Dynra Rockets (01-06-2018)
Old 01-05-2018, 08:45 PM
calwldlife
calwldlife's Avatar
St. Jude Donor '22
my brother and i went to their shop 20 or so years ago.
got some 65 chevelle arms.
I imagine they are a shop full of peole now. :thumbs
Old 01-05-2018, 09:26 PM
427Hotrod
427Hotrod's Avatar
Received 1,873 Likes on 911 Posts
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Originally Posted by Neil B
I installed my Viking shocks with the shocks inside/on top of the welded nuts. Much better than having the bolts take all the weight.
I believe that's how instructions show also? Don't remember.
JIM
Old 01-05-2018, 11:30 PM
BlackRocket
Correct me if I am wrong, but I would think that the same size coilover in the y dimension; (length) has to have a certain amount of spring tension to keep the coil in place when suspension is at full extension. So given the same size coilover at the same tension the "extended" lower control arms would lower the vehicle the 2" as the tech rep at Global West mentioned??
(I would think to maintain the same ride height the coil and shock strut would have to be 2" taller/or a 2" larger unit)
Does someone know for sure?
Thanks!
B-R
Old 01-06-2018, 01:27 AM
Neil B
Neil B's Avatar
JIM
I'm running a stock style spring, not the semi coil over. The weight of the car is not on the lower shock mount in my setup. I bought the threaded body shock so I can upgrade to coilover at a later time.
Old 01-06-2018, 08:27 AM
bazza77
bazza77's Avatar
just wondering , can you still reach the adjustment *****/dials with it set up like that ?
Old 01-06-2018, 10:20 AM
Neil B
Neil B's Avatar
Yes but the ***** have increased resistance at the higher settings. I think I could adjust them in the softer ranges without dropping them. Stiffer settings may require me to pop them out real quick.
Old 01-06-2018, 08:14 PM
TCracingCA
TCracingCA's Avatar
Received 1,679 Likes on 1,002 Posts
This is correct!
Old 01-07-2018, 12:09 AM
427Hotrod
427Hotrod's Avatar
Gotcha...should have looked at the pics closer!!
JIM
Old 01-07-2018, 06:01 PM
BlackRocket
I decided to go with the standard Global West lower control arms for coilovers as I already have clearance issues! My side pipes are currently at 5 1/2" and will only be able to go down about 3/4" to keep from dragging them on every speed bump in town!!!
http://www.globalwest.net/corvette-t...1971-1972.html
Old 01-06-2019, 05:45 PM
Factoid
Factoid's Avatar
Received 5,505 Likes on 2,778 Posts
I have a C2, but as part of my build I’m going with 17x12 wheels with 335/35-17 tires, so I upgraded to C3 spindles and am using these GW ext control arms with Ridetech coilovers. The quality and adjustability is amazing. To the earlier question about the adjuster, it comes out the top of the shock and is easily adjusted from the engine bay. I’m using the Ridetech coilover set up in the back, but have not installed it, yet. My ‘64 will be lowered 2” all around.
Old 01-08-2019, 08:52 PM
TCracingCA
TCracingCA's Avatar
The only thing I don't like and it could be a quirk with the car (no accident damage), is that the can alignment isn't perfect for coilivers or semi-coilovers! I thought above cutting the can, but instead am making two different top of can bolt on plates (one for a return to a conventional spring or take that off and put on a top full coilover spherical mount! I like the larger coil over springs, so I dropped the mount location slightly on the top mount, to avoid top of spring interference to the can! The extended lower, keeps me good on travel when lowered!
To Global West "extended" lower control arms...
Quick Reply: Global West "extended" lower control arms...
