BB vs SB 69 auto modulator vacuum line??
Can anyone tell me what the difference is between the BB and SB auto (400) modulator vacuum line? I'd like to replace the line in my 69 SB and the only one I can find is a replacement from Paragon (4061) that's for a BB. No SB line to be had. I was thinking about just buying this one but I don't know how different they are. Any thoughts, help, or leads on where I might get one that's either new or one that's in good shape?
The BB line might be a touch longer. Be easy to fab your own too. Piece of 3/16 brake tube and have at it. It's got a rubber connector on each end so exact is not required.
St. Jude Donor '22
i thought the vac mods were different in what range they operate?
seen many modules that had fat hoses stepped down to smaller ones?
drop by a transmission shop and pick a brain.
Past that, vacuum is vacuum. Short of installing a controlled leak in the line, it's sees vacuum and does it's job.
St. Jude Donor '22
The modulators are pretty much the same. Some are adjustable- there's a screw slot inside the tube- about 2 turns either side from where the manufacturer set it- any more you risk tearing the diaphragm.
so much stuff in my head that lately it doesn't fit
together.
- talk about useless noise in there!!
