Advice on Torque Converter
http://ftiperformance.com/Economy-Pe...erters_c80.htm
As good as it would be to have all of the info on your engine, its not entirely necessary for what you are doing..... The ball park data is that its less then 400hp, 3500 lbs (give or take without a driver), mid 3.xx for gears and a T400....Street cruising and possible drag runs, looking for a good idle in gear. They'll be able to get you close enough...
Its not like you are talking about a 700+ HP race car you are trying to run 9s with. I definitely would not take apart a good running engine to try to figure out what the cam is, just to spec a street converter...LOL...
BTW,
B&M, TCI, Summit, Jegs converters all suck.... stick with a real converter company.... FTI, PTC, Dynamic, Ultimate Converter, Coan....or if you're rich, ATI, Neal Chance etc...
I've had great luck with FTI and all my friends with fast Vettes are running them...(8.50-9.30s cars)
One other note, if you haven't checked the timing and carb adjustments, I'd do that first, that will likely help your idling in gear issue.
Summit helped me alot and we were able to come up with an appropriate converter for my engine combination. I knew roughly what RPM the engine started making big power at and max RPM. Rough compression ratio, transmission and rear end ratio.
I think I ended up with a Hughes and its been fantastic. 3500 stall, but its a 355 with like 500hp 13:1 compression and revs to about 7k
Call the pro's, but make sure you discuss highway speeds and your intended use. Too high of a stall rate may affect fluid temp, if stall doesnt happen at highway crusing speeds. I planned for it in advance and installed a trans cooler because mine doesn't stall until about 75-80 MPH depending on load/grade
But before you do that
What rpm does it idle at in gear ?
What is the idle timing at ?
Here are some tips on TQ converters.
Most cheap companies simply reduce the diameter 11" inch to a 9". This causes what people think is slipping , or a higher rpm to move off idle " The engine revs more"
That happens because the distance traveled to complete a single rotation is increased , JUST like rear tires affect final drive ratio. Go to a 2 inch smaller tire and take a drive. You will see higher RPM at teh same speeds when compared to the original tire size ( 27" vs 25" which causes more rpm ) Also never forget a Torque converter "Multiplies Torque" Under its STALL SPEED and a smaller TQ/converter produces less multiplication under its stall speed.
A quality converter is built for its flash stall and can remain the same size as the OEM converter. This allows for ZERO driving changes in what you feel when you pull away normal from a light.
And when you Stomp on it The flash stall delays the 1 to 1 input rpm to teh desired speed which will varry slightly from one motor to another.
I run a 11" 3600 to 4000 stall in front of my 4L80E , I have 4.11 gears and a SBC 427
The drive ability under daily driving conditions is perfect. I pull away and my motor barely revs , It idles perfectly at 750 in gear and when I let foot off break it drives forward normally and it holds on inclines.
Basically with 600hp it drives like any car with sub 400 hp ..
But when I get on it , the 1 to 1 power transfer is high enough up the rpm range to give me the RPM I need to get into and stay into my torque band.
Also when you raise the stall speed. The RPM between shifts DOES NOT DROP OFF pulling the motor down. We all know what this feels like. Go drive a basic car with an automatic. When It up shifts from first to second the motor drops alot of rpm and has to power its way back to high rpms.
A well made converter eliminates that , When i shift from 1 to 2 the rpm drop is only a few hundred rpm keeping my motor spinning hard producing its peak power from the time of the shift and all through second and into 3rd. My motor does not need "Recovery time" its always pounding out at high rpm when I run full out.
I had a few minutes..
I Hope this helps add to the discussion
I just wanted to add this. A larger or identical diameter TQ/Converter built for your stall speed will also allow the transmission to operate cooler and it maintain's the correct quantity of Fluid specified by the manufacture
You are right... Summit and Jegs don't make converters.... They use cheap *** companies like Boss Hogg, Freakshow, and who knows other back yard converter builders to supply their junk.
B&M and TCI are both good companies and make good products, but their converters are nothing special...basically off the shelf, inefficient junk that costs nearly the same as a quality converter.
If you haven't heard of FTI, that tells me you don't hang around the fast guys. FTI, PTC, ATI, Coan, Neal Chance, these are the GOOD converter shops... They can build you an 8" 5000 stall converter that drives just like your 2600 stall B&M Holeshot converter on the street.
There is so much bad information on this forum in regards to stall converters, its unbelievable. People stuck in the 70s-80s mentality trying to give converter advice.
Calling FTI or ATI is good advice if you want to pursue it......
I quit using TCI and B&M years ago because it seems like no two come out of the box with the same stall......just an opinion.
Jebby
I had a $200 Boss Hogg ACC 10" (2800)converter from Comp sales behind a 406" Pontiac, The converter was terribly loose, very inefficient. The car left good but wouldn't mph.... Low 1.6x 60's but would only trap 108 in the 1/4. I ran it for a year until I had some extra money and decided to "upgrade" to a TCI Super Street fighter 10" ($350)...Guess what, the car went slower, wouldn't 60' less then 1.72 and ran the same mph....
Then I put a 175 shot on the car and it blew right through the converter and wouldn't even finish the 1/4 mile (out of rpms).... Upon calling TCI, they recommended I go to a "custom race converter" for my application.....LOL Really? a mild Pontiac on a small shot? Yeah OK.... F TCI...
Learned my lesson on cheap converters long ago.
ON the contrary, the Hughes brand, GM25, (2500 stall 11") is a pretty decent converter for $250. I just installed one behind a mild 355" with 3.73 gears, its a little looser then I thought it should be around town but, its quite livable and seems to have a decent flash....I haven't beat on it much yet as its on BFGs but its a decent converter for the money, at least decent enough for my 66 year old Dad to creep around with.
Behind a real motor, it would be pretty damn loose around town....
By comparison, my locally built, custom 10" converter in my 71' drives basically like stock, pulls away from stop lights without throttle and pretty much feels like stock until you go 50% throttle, then it starts to loosen up as it should. Mine flashes to about 3500 rpms on dead hook launches leaving at idle and measures about 10% converter slip in the traps...Not too bad for a $300 converter.
so the things you should look at are efficiency and maximum hp rating. Welded fins, anti ballooning plate, sprag or spragless
vigilante, art Carr the business not the person, continental, or maybe this 700 hp
http://ftiperformance.com/Street-Rac...0-TH400-SR.htm
I've been trying to learn as much as I can to set up my 73 496 BB, with a cam operating range of 2000-5800 rpm, recommended lock up of 2500 rpm and trying to run an auto overdrive with a cruising rpm of 2000 @70 mph.
I'm getting different answers every place I turn and at this point I'm about to throw in the towel and convert over to a manual 5 or 6 speed transmission.
Its frustrating.
Its frustrating.
In my 800 HP capable 700R4 one of the improvements was a larger high pressure 26 vane pump. The higher pressure made for more clamping force on the lockup clutches. Many year ago the quality TC companies came up with multi clutch disk lockups. My $1100 9.5 inch was a 5 disk lockup model. My tranny was setup for no auto kick down when you went to full throttle and lockup in 4th gear only and 4.11 rear end. It ran fine for years with a 383 solid roller motor and I had it built with my power level to be a 3500 stall. It was capable of very high MPH when competing in events like the Silver State classic open road race.
I got the HP bug and installed a 7500 rpm Solid roller 427 ci. I floored my Vette in lockup 4th gear and the TQ of the motor smoked my 5 disk lockup. Instead of fixing the highly efficient TC, I just drove it around for the next couple years without lockup.
when my lockup still worked I would on see a 100 - 200 rpm difference on level freeway driving when I flipped my lockup switch on. That is with a 3800 stall TC. Because of the TQ of the 427 compared to a 383 it changed me from 3500 to 3800 rpm. I had the big B&M tranny cooler and even on the over 100 degree days I never saw tranny temps exceed about 200 degrees out racing and under less load it would get down to about 160 in city driving.
My advice for a 496 ci is to forget lockup or go with a multi disk unit that unlocks if the throttle is opened up. I am pro higher stall highly efficient TC's. I have a Dodge 3500 dually and when I'm pulling my toy hauler I kick it out of OD lockup on any hill because I don't want to smoke it with 800 foot pounds or something of TQ when it gets up to 30 psi of turbo boost.
I hope this helps you.
George
It cannot be commanded until I reach 45 in 4th gear only
And it unlocks the instant I push past 10% throttle
So you can have all the top latest greatest ideas on a high hp car. It all comes down 2 how it is built and tuned.
I remember what converters were like back in the 70's and 80's. Most of them were very loose and sloppy. Some of the inexpensive ones on the market today aren't much better. There was a local guy back in the 80's that built very inexpensive converters that worked really well. I had one in a 64 El Camino with a big block I built that worked really well, but it wasn't the norm back then.
Mike
