Changing over from side pipes back to stock rear exit on Lt1
The replacement rear valence is available:
https://willcoxcorvette.com/corvette...s-molded-70-73
You’ll also need a chrome part on each side that fits around the cutout. With luck, theyre in your parts pile.
All Right Guys,
I went and picked up a lot of the spare parts from my dads house this weekend, and took a closer look at the car and
I have decided to do away with the side pipes, and have my exhaust shop put in a new system from the header back. I am thinking of the following!
Shorty headers- Any Suggestions
2.5 back w/ H pipe or X pipe what's best for scavenging hp?
Into Chambered Mufflers and out the back in stock location
Can I purchase new valances with cutouts for rear exit, or is it best to just have the muffler shop cut them out?
If it's "one piece" then you can probably replace it with a stock piece and sell the one you have. If it's the original with the cutouts simply glassed over OR with filler pieces in place of the cutouts then personally I'd likely reverse what you have.
Bezel! As a side note, any part that you can’t figure out a name for is either a bezel or an escutcheon.
https://www.ebay.com/itm/1970-1973-C...lZvAea&vxp=mtr
Which ever way you decide to go, do the pipes in stainless steel. It will cost you a little more now, but will be well worth it down the road when you don't have to replace it in a few years.
Duane
Duane
Received 2,878 Likes
Hi,
Here're a couple of photos of the valance being changed from the side exhaust rear valance to the under car rear valance.
How you proceed, and what valance you use, will depend on how the part of the original under car version of the exhaust opening in the QUARTER PANEL was handled.
You may be able to cut the exhaust bezel opening back into the quarter panel; then you can use an under car exhaust rear panel.
You do need a flange on the quarter panel and exhaust panel to bolt the 2 together and mount the exhaust bezel.
If you're sneaky you can do it without having to paint the quarter panel... just the valance panel..... and maybe not even that depending on how the opening was filled and if the flanges were cut off.
Regards,
Alan
Regards,
Alan
Hi Td,
Looking at the photos I can understand why you're excited about this car!!!
Regards,
Alan
Regards,
Alan
Thnksdad (04-01-2018)
Beautiful car. Congrats. FWIW I have a system from Corvette Central and I really like it. Its a reproduction of the factory 2 1/2" dual exhaust system. I have the factory style mufflers but the system is also available with Magnaflows if you want a little more volume. I like the factory style system because the factory designed it with a bunch of crimps and tweaks to maximize clearance, which you don't usually get with a custom system from a muffler shop, no matter how good they are. Yeah we can argue that the crimps reduce flow, but I doubt if its a lot, and I would give up a couple of horsepower to not drag my exhaust over every speed bump and pothole.
If the rear valance is filled in there is no way I'd cut it back open.. you can get factory style pipes that are quieter. And there are fiberglass covers that can be painted. Some places can even put a chrome like finish on them.
There's no way I'd take a saw to that back panel
If you have a chance and the dollars get rid of the restrictive 2" air cleaner assembly. You need the factory style drop base air cleaner with the 3" element.
I will order one where would you suggest? I want to get the chrome distributor cover as well. I am also installing the crt distributor will the cover fit?
#34
I would do real full length headers, 2.5” exhaust, with an X pipe, and non chambered mufflers. (Unless you use the Hooker Aerochambers, they are straight through flow).
I’d do the Hedman 1 5/8” headers with ball flange collectors, 2.5” aluminized or stainless pipes, into some good mufflers like Magnaflow, Pypes, or the Aerochambers. Then put the stock 1970 square tips on them. It will look, sound and run much better then side pipes.
Thnksdad (04-05-2018)
#35
Hi Guys,
Is this the aircleaner you are referring to? I probably only need the base though.
https://www.ebay.com/itm/Chevrolet-C...53.m1438.l2649
#36
#37
Looks like they were glassed in! That should be a easy swap back to Factory Exhaust now!! Thanks for all the help guys. I will post picture when it has the new exhaust on it.
Derek
#39
That site with the chrome air cleaner lid shows a photo of the drop-base part, but I don't believe that is part of the sale item for that price. I think that price is just for the lid.
