1972 Corvette - Radio Does Not Work With Key in Accessory Position
Folks:
My brother and I are continuing to troubleshoot electrical bugs after full body off restoration of the car.
Here is the next item on the list.... The radio does not work with the key in the Accessory position. When you turn the key to all the way to on position, the radio works. We've looked online, thru the Assembly Information Manual, Service manual, schematics, etc., and are unsure what to try first. Could the issue be with the ignition switch itself? According to the pictures I've seen online, the ignition switch has 9 copper terminals where it appears either individual wires or a wire plug is connected. Could the issue be with one of the terminal connections? Also, tracing the schematic (I don't have it available here to view at moment), it references a radio capacitor. We have been unable to locate that or find any reference to it online or in the online Corvette stores.
Any help in getting started troubleshooting this issue would be appreciated!
Thanks!
Regards,
Roger
Thanks!
Regards,
Roger
I'm not an electrical guru by any means, but it sounds like your problem would be in the ignition switch itself. Forget about your mystery capacitor. As you stated, the radio does work, just not in the accessory position. My car is all put away for the winter so I can't go out and check but does anything else work in the accessory position? Off hand I don't recall what else should work. Maybe the accessory position is dead in your ignition switch.
Duane
Duane
try adjusting the ignition switch on top of the steering column. loosen the screws that hold it in place and slide it fore and aft to find a position that the radio comes on.
rdupler2 (02-17-2018)
Received 3,218 Likes
In the acc position- the wipers should work as well.
If the wipers don't- then you more than likely have an ignition switch issue.
See the drawing below-
If the wipers work- more than likely the radio has been connected to a source that is not on during ACC- like the gauges power source.
The brown wire goes from the ignition switch to the fusebox- and powers both the wiper and radio fuses.
BTW- the capacitor does nothing but eliminate noise in the radio.
Dementer sole survivor
Received 6,260 Likes
2016 C3 of Year Finalist
I would check the plug into the radio. See if it's plugged in correctly. Then turn the key to accessories and check for power at the plug, then at the fuse box.
Regards,
Roger
As I recall, the wipers did work in the Accessory position. Will double-check that this weekend. We're doing all the work in my brothers garage so all the schematics and other documentation is over there and I can't refer to it and compare with your diagram at moment. Did that come from the schematics in the Service Manual? As I mentioned, when you look at pictures of the ignition switch sold online, it shows 9 terminals. Your diagram appears to show 6? But maybe what you are showing is not the same thing?
Thanks to everyone for the replies. I'll be getting back on this Saturday morning.
Regards,
Roger
Richard:
Regards,
Roger
Regards,
Roger
It's a little of both- I have a PDF wiring diagram and made that drawing from it.
Here's a downloadable wiring diagram for your 72-
http://www.keystonestatecorvetteclub...tte%201972.pdf
IF the wipers are working in ACC- then it is not your ignition switch.
HOWEVER- somebody could have changed something is the past 45 years!!!
To verify- put a test light- or a meter then measure voltage at the fuse (radio and wiper) with the ignition switch in ACC. No need to chase your tail.
IF you see power- somebody has changed the source for the radio's power. Yellow +12V (ACC/IGN but not during cranking)
Black is ground and gray is interior light.
Richard
A 72 radio-
Richard454
I want to thank you for taking the time and effort to post all the diagrams, schematics, and pictures. They were all helpful and great for future reference and I will be eternally grateful for your help!
In the end, the issue was fixed by adjusting the switch location as proposed by Oldboat and Redcruz.
Oldboat, Redcruz:
Thanks for the suggestion to adjust the switch location. That is what fixed my issue.
..and thanks again to everyone for jumping in to help It's because of folks like you all that makes this hobby possible and fun!!
Regards,
Roger
Oldboat, Redcruz:
Regards,
Roger
