80 383 quadrajet running rich
My 80 383 with has been running fine since I put the quadajet from National carbs on a year ago. When I drove it the other day it started fine and ran good until it worms up. I drove it two more times and it still does it. I took the carb apart and looked around twice. didn't see anything wrong. I looked at the underside where the idle circuit was drilled and epoxied and no fuel. I checked the filter and needle and seat all looked ok. The float worked. When I remove one of the small vacuum lines the idle cleans right up so its got to be rich. Any ideas?
Calo69 (03-07-2018)
when you had it open did you check the float level?
did you check if the float is leaking/gasoline loaded?
did you try adjusting the idle mixture screws and if so do they cause the rpm to drop as you turn them clockwise?
