No Juice
No Juice
I Put a new starter in my 74 and went to try it I had no power to the car. Put a tester on the battery,under draw it showed weak. I have no interior light or horn. Any ideas what to check next.
Your fusible links down by your starter can be messed up ...THUS...not supplying power to your fuse panel.
Do you have a wiring diagram?????
DUB
DUB
If not, re check all connections.
Did you disconnect the positive and negative cables from the battery before you swapped the starters?
Check all fuses and relays to make sure you did not blow anything.
try try again.
Did you have a starting problem before you replaced the old starter?
